Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 34 Alum. Grill
Thread: 34 Alum. Grill
Old 10-09-2012, 02:25 PM
FASTFORD's Avatar
FASTFORD FASTFORD is offline
Originally Posted by 302 Z28 View Post
Are you using the original radiator mounting springs/bolts & washers? If so you should be able to adjust somewhat the height of the radiator. Or as a last result modify the lower radiator supports to lower the radiator. I also would not do any work on the grill as they are far too expensive to screw up.
Vince
this is an excellent option......imo
