-   -   34 Alum. Grill (http://www.hotrodders.com/forum/34-alum-grill-224800.html)
Jmccrack 10-08-2012 10:57 AM
34 Alum. Grill
My 34 grill hits the top corner of my rad both top corners. Has anyone ever ground a small amount off the backside of an alum. grill for clearance? I only need to take off about a 1/16"
FASTFORD 10-08-2012 02:37 PM
I`d like to help but this is the first time that I heard of that problem.
I will suggest, look for another way to solve the problem before grinding the grille.........
Irelands child 10-08-2012 02:46 PM
Why not just adjust the radiator support rods back about 1/16" ? Do it at the radiator end
http://static.speedwaymotors.com/ima...w-91124001.gif
Jmccrack 10-08-2012 07:51 PM
Thanks for the help guys. On a 34 ford the center hinge is 33" long and a Rootlieb hood is made to fit this dimension. When the grill frame is bolted to the top of the rad as it is on a 34 Ford with a 4 piece hood the grill and grill shell is now a fixed distance distance from the front on the rad. In my case the top corners of the rad hit the inside of the grill shell insert. All I need is another 1/16". I think I have solved the problem. I was able to trim a bit off the rad frame on both sides.
302 Z28 10-08-2012 09:18 PM
Are you using the original radiator mounting springs/bolts & washers? If so you should be able to adjust somewhat the height of the radiator. Or as a last result modify the lower radiator supports to lower the radiator. I also would not do any work on the grill as they are far too expensive to screw up.
Vince
FASTFORD 10-09-2012 02:22 PM
your information is correct but I immediately thought, elongate the holes for mounting the grille shell to radiator to gain the needed clearance.
would this help...yes,no,maybe ?
FASTFORD 10-09-2012 02:25 PM
Vince
this is an excellent option......imo
Jmccrack 10-09-2012 05:53 PM
34 grill Shell
1 Attachment(s)
Thanks guys for the response. I ended up taking about 1/8" off 3 ribs on each side and this did the trick. If I had move the top of the rad I would have had to buy another hindge and the hood side lines would not line up. If I elongate the 2 holes in the top this would also work but my center hinge would Not be long enough.
FASTFORD 10-10-2012 03:21 PM
now I understand better.
not all aftermarket items fit like factory equipment and you are building a re-pro. some things just do not fit together in a situation like yours.
keep at it :thumbup:
dinger 10-11-2012 08:08 AM
If you get a chance, why not start a journal of your build? We'd love to see the car and you might help someone else.
