Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 34 Chevy underfloor brake install question?
Old 01-18-2006, 05:21 AM
lowROLLERchevy's Avatar
lowROLLERchevy lowROLLERchevy is offline
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
you want enough pedal above the floor that your foot is centered on the pedal even when its fully depressed
if the pedal moves to close to the floor as its depressed, the floor will interfere with the heel of your shoe, and in a panic stop situation, you could easily stomp the brakes, and actualy be putting most of your effort into the floor and not the pedal
go out and measure your daily driver, and put the pedal the ame approx distance from the floor
if you cant get it that high because of the units design (mount hits the floor), then just go max height it will allow
