'34 engine work - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2013, 09:35 AM
'34 engine work
next week, I have to check out a '34 Chev ( or Ford ) , owner says it has a knock. So, I'm assumming it's a bearing.. it would have those babbit bearings, ... Which makes me ask, where and how do I get the rods, bearins,and maybe crank ? Also, I have other motors,,but a babbit one, would it be any more difficult ??.....thanks
Old 05-30-2013, 09:56 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
There are a kazillion suppliers for internal motor parts, parts stores, Summit, Jegs and more.
What "other motors" do you have that are not babbit bearing motors??
Semper Fi
Old 05-30-2013, 12:51 PM
I'm sorry ! I guess I was in hurry t0o post this, and on to something else. What should have said, is , I have DONE other motors before, never a 'babbit' kind . I've done a 235-6 about 8 years ago, did my wifes Cutlass 350 2 years ago, MANY years before, I used to do some farm tractors, and the Deisel truck motors, BUT, never did a babbit thi Just wondering what I would be in for !!! thanks for the intrest !
Old 05-30-2013, 03:26 PM
babet brgs
you need to find a verry old machinest,1 skilled in pouring babet and machineing to the sze of the cranh,and or block.babet is a mixture of lead and other ingreadiances,the old machinist will know all about good bad and ugley of the trade. good luck
Old 05-30-2013, 06:23 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
The only poured and sized bearing shells I've worked with were in Westinghouse turbine generators (shaft bearings) I worked with for the Air Force at their power plants. Large 9.5 megawatt units.
What motor are you talking about here that requires a craftsman to pour custom babbit inserts for? I'm confused!
All current automotive motors I'm aware of use babbit inserts, you know, the old crank and main bearing sets you buy from the parts house. There have been some roller bearing motors years ago, Honda's little sports car year for one, but they didn't pan out.
Semper Fi
Old 05-30-2013, 06:38 PM
BOBCRMAN@aol.com's Avatar
I do babbit motors often. Currently a 24 Ford.
I get rods/block done (babbit poured) by Pauls rods or Effingham re-grinders in Effingham Ill. www.effinghamregrinding.com/aboutus.htm-I have a grinder in Pontiac, Mi. That welds and grinds the crank pins back to standard. .
Find an old astablished machine shop that does farm/commercial equipment (maybe oil rig stuff?). They will give the low down on costs in your area.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
68NovaSS (05-30-2013)
Old 05-30-2013, 07:29 PM
babet bgs
model a has babet ,early chev 6cyls first flathead fords had babet pored mains.
model t fords
The Following User Says Thank You to cliff tate For This Useful Post:
Old 05-30-2013, 07:50 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Ahh, I wasn't considering an older stock motor from the early days. Thanks.
Semper Fi
Old 05-30-2013, 09:52 PM
Wiki Edits: 27
Babbit bearins/
You need to find a club in your area that caters to original restored old cars, Eg model T Ford Club of america, chapters , Model A ford club. Early ford V8 Club. Horseless carriage club ETC Those guys know who does babbit work. how long it takes for the semi retired guy to get to your project. It takes a set of molds for the babbit, to be poured , then when it has cooled they are sometimes pounded to set them, then rough boring, then dye, turning the crank to see the shinny high spots, then hand scraping , repeat, lots of time, $ $
Old 06-02-2013, 08:50 PM
that sounds like the answer I was looking for... at a car show yesterday, I asked around also. Got all few "intresting' answers ! Some were kinda 'out to lunch'... thabnks guys, that what I wanted to know. If any one is intrested, let me know here, and post the repair job
Old 06-02-2013, 09:04 PM
babbit motor
I have a great running 194 six cyl. out of a 31 chevy. Also trans,rearend,frontend and steering wheel and column. I'll take 500 for it all if you are interested. May be to far to travel. Joe
ID:	74574   Click image for larger version
ID:	74575   Click image for larger version
ID:	74576   Click image for larger version
ID:	74577   Click image for larger version
Old 06-03-2013, 09:03 AM
well, I'll know more in a week or 2. like I said, I'll post the complete repair, if any one is intrested...
Engine restore Does it work? rick_458 Engine 133 10-17-2016 09:50 AM
Cost for some engine and misc work SBCfan04 Engine 2 02-02-2010 08:48 AM
Engine Work to be done Ozz1967 Engine 11 01-14-2008 01:08 PM
engine swap will it work 75sprintguy Engine 9 09-02-2007 10:14 AM
Engine Work Costs 73fj55 Engine 5 02-23-2006 12:56 PM
