34 Ford 3 Window Coupe tilt Hood - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2010, 09:31 AM
Does any one have any knowledge of who can assist me with selling or making a 34 Ford 3 Window Coupe tilt hood.Pop-Pops Toy
Old 12-30-2010, 03:37 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site.
Cole
Old 12-31-2010, 12:56 AM
Thanks
Cole
Thanks for the thought.
Old 12-31-2010, 04:55 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
To make a 34 tilt front one needs to either bolt or weld the fenders hood and grille shell into one unit and then hinge it at the lower point of the grille shell.. Lots of KW and Peterbuilt trucks have this feature so you can get some ideas from that..Also you can do a search on google for tilt fronts for more ideas..
http://www.google.com/#hl=en&expIds=...989c6c17f79c85
Sam
Old 12-31-2010, 10:30 AM
302 Z28's Avatar
This would be a tough one because so much of the front end of a 34 Ford is keyed off the radiator. As mentioned the fenders and hood would all have to be welded together and mounting brackets fabricated and mounted to facilitate the one piece arrangement without any attachment to the radiator. It probably would be much easier with a glass front end.
Vince
Old 12-31-2010, 12:04 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
I'm thinking he might mean just the hood..
Old 12-31-2010, 12:30 PM
dinger's Avatar
Tilting to one side or the other may not be too hard, tilting to the front or back may be pretty difficult. To the side, use the front on a pivot with a sliding rod. A one piece hood would be needed, solid sides or no sides. Scroll down this page, there are a few to look at. here ya go
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 12-31-2010, 06:33 PM
Tilting the hood to the front isn't to hard, You need to do it with four bar's..
And if you want to tilt it to the back, Just buy the right hinges..
Old 12-31-2010, 06:43 PM
35terraplane's Avatar
tilt hood
I have seen them where just the hood will lift up. SB goes up from one side, and someone makes a hinge that the hood will tilt from either side.
Bob
Old 12-31-2010, 06:53 PM
If your talking about a whole front tilt.. Here's a car I built.. I made it tilt.. Not a 34 but may give you some idea's..
ID:	51226   Click image for larger version
Old 01-01-2011, 08:44 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Randy: Why don't you post your other pictures of other cars you have done this way? BTW, Happy New Year.
Old 01-01-2011, 10:33 AM
Thanks Mr. Dan.. And I hope you have a blessed New Years.. I was going to post them, But I thought this was the close's one to a 34..
ID:	51231   Click image for larger version
Old 01-02-2011, 11:11 PM
MR.E.Stranger's Avatar
"king 6:23"
That truck reminds me of my old wb one toner ecept it was set up as a work hack if you don't know what a wb is just wiki Holden commodore or kingswood (ps kingswood is the predecessor to the commodore)
Old 01-04-2011, 05:10 PM
If your talking about just the hood forward.. Here's something that might help you..
Name:	all pics 2045.jpg
Old 12-29-2012, 04:29 PM
Last journal entry: complete 2007 corvette in a 34 ford
34 ford tilt front end
got my 34 to tilt
Wasnt too hard with a one piece nose that pivots on the radiator support
ID:	70193   Click image for larger version
Name:	tilt front end.jpg
ID:	70194   Click image for larger version
Name:	tilt front end 2.jpg
ID:	70195   Click image for larger version
ID:	70196   Click image for larger version
34 Ford 5 Window Coupe rmkstreetrods Introduce Yourself 1 02-16-2008 04:11 PM
36 ford 5 window coupe rhussey Introduce Yourself 1 11-22-2007 10:03 AM
36 Ford 5 window coupe SlovakLen Body - Exterior 9 08-11-2007 12:40 AM
ford 5 window coupe guts Introduce Yourself 7 05-04-2007 10:29 PM
36 ford 3 window coupe thenry Body - Exterior 0 12-18-2003 08:43 AM
