Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 34 Ford 4 piece hood
Old 01-12-2012, 01:45 PM
Jmccrack's Avatar
Jmccrack Jmccrack is offline
Last journal entry: Inner Fender problems
OK guys I need some help. As you can see in the picture I have only 3 solutions as I see it.
1. Cut the hood hinge back and bolt the hinge bracket where it sgould be
2. Add something under the hood on the top of the rad to extend the hood bracket back
3. Bolt the hood bracket hinge to the fiber glass grill shell.
If I do the first one I will have to fill the area I cut out. If I do the second one I am not sure the hood will drop down far enough. If I do the 3rd one is the fiberglass strong enough to hold the hood. Any help would ne greatly appricated
