34 ford body mounting - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2007, 12:21 AM
anyone know the measurments for locating a coupe body on a repo frame
Old 09-08-2007, 12:47 AM
powerrodsmike's Avatar
Wiki Edits: 161
Usually the shape of the floor will locate the body on the frame, the kickup over the rear axle is a natural alignment feature. I usually pull them back up the "ramp" created by the frame kickup, then let the body settle down .
Does your body have a floor in it?
Another locating feature is the crowsfoot shape in the rear wheelwell. The vertical line in that detail will point at the axle centerline.
There is a hole in the side of the frame just behind the leading edge of the wheel opening where the rear fender bolts into it. If you have a fender, you will see where it goes.
You can also use the splash pans to locate the body at the front if they are the steel ones.
later, mikey
BE different....ACT normal.
34 Ford project rhphotrod Introduce Yourself 19 06-28-2010 01:08 PM
wanted frame spec's for a 34 ford 3window coupe wogi 34 General Rodding Tech 3 12-19-2007 08:15 AM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
34 Ford Side hood grille/vent? Pilot34Coupe Body - Exterior 5 02-28-2003 07:15 AM
34 ford outlaw body front inner fenders vette66 guy Body - Exterior 4 02-03-2003 05:21 PM
