Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 34 ford coupe
Thread: 34 ford coupe
Old 12-16-2004, 08:54 AM
Centerline Centerline is offline
Wiki Edits: 49
Re: Framed
Originally posted by Max Keith
Im attatching a set of blueprints I robbed from a catalogue of a well known company that sells glass duece roadsters.
welding small panels together to make a big one will achieve a lot of warping. Most car bodies are made from 16-18 gauge steel.
From the blueprint I sent you can extrapolate the other dimensions by measuring the known ones and make your own scale for the rest.
The deuce frame info will be helpful for people building deuces or Model A's on deuce frames but the 33/34 used a different frame.
Centerline
