34 ford coupe, e brake pedal on cowl? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2013, 07:04 AM
Mitchman's Avatar
Grand Master of the Universe
I'd like to keep the floor looking clean. Has anyone installed an e brake pedal on the cowl? Is there enough room/foot clearance? I know it's tight... how far does it have to sit from he side wall?
Thanks.
Old 05-30-2013, 07:20 AM
Wiki Edits: 27
ebrake
You have to see if your foot would fit in the space, then be able to mount it to clear your upholstery. I broke a few bones in my left foot and have to use my right foot to set the e brake hard on my F 350 truck. I have seen floor mount handle e-brakes mounted side ways just in front of the Pass seat. I have a forklift-tractor E brake that you can adjust by twisting the handle that I plan on mounting sideways.
Old 05-30-2013, 07:28 AM
Banned
or the old mopar underdash hand pull early 70's
Old 05-30-2013, 08:22 AM
sedanbob's Avatar
There really isn't much room to the left of the steering column to add in an e-brake pedal. There are some hand lever types that mount between the firewall and the dash. Lokar makes a nice one, but it's pricey.
I used a floor mounted e-brake, between the seats. Since the seats are so close together, the e-brake doesn't hardly show. The floor in front of the seats remains clear.
Old 05-30-2013, 08:39 AM
Mitchman's Avatar
Between the seats is prime real estate. (Mid 80's Fiero seats gives me about 5". In a 34's cockpit, that's a basketball court) I'll have to mock-up the column, etc and have a look. I'm thinking it's going to be too tight, but one of the hand levers might do OK - if it doesn't have to hang too low.
Old 05-30-2013, 01:39 PM
Banned
go back to the fiero and get it's e brake handle it's on the left side of the drivers seat on floor
Old 05-30-2013, 03:29 PM
sedanbob's Avatar
Your Fiero seats must be a narrower than my seats - I might have 5 inches between the seat mounts, but only an inch or two at the most between the cushions. And yeah, space is at a premium in a '33/'34.
I don't know if I trust them myself, but there are electrically operated e-brakes - you'd only need space in the passenger compartment for a switch - very expensive - north of $400! E-Stopp Electric Emergency Brake Kit - Speedway Motors, America's Oldest Speed Shop
1931 model A coupe cowl repair. speedydeedy Body - Exterior 13 02-12-2013 09:44 PM
Relationship between Gas Pedal and Brake Pedal 35WINDOW General Rodding Tech 12 01-11-2012 01:35 PM
53 Ford coupe Brake Lights ?????? 53vic Electrical 1 08-21-2011 11:08 PM
1999 Ford taurus wagon, brake pedal sensor........ Trans Am Tony Suspension - Brakes - Steering 3 09-04-2007 06:49 PM
brake pedal sxcorpio Suspension - Brakes - Steering 1 04-24-2007 08:41 PM
