Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '34 ford - Fastening the hood side panels at the bottom
Old 04-02-2013, 06:04 AM
sedanbob's Avatar
sedanbob sedanbob is offline
Mine has pins on the hood side that fit into a bracket attached to the apron. A small tab that hooks over the apron would work - you'd probably want to add a something to cushion so the side doesn't rub the apron and the clip doesn't rub the inside.
