Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 34 Ford Front Axle
Old 02-22-2003, 06:10 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Post
I believe the difference it the thickness or height of the king pin boss at the end of the axle, the 34 being thinner, you could easily make up a spacer to make up the differance, i have used early econoline spindles for these type axles, you have to cut off the factory arm and use a hot rod one from Speedway
[ February 22, 2003: Message edited by: BOBCRMAN@aol.com ]</p>
