Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 34 Ford Front Fender Center Clip Help...
Old 05-12-2010, 12:27 PM
Metal Twister's Avatar
Metal Twister Metal Twister is offline
Change is Opportunity!
Last journal entry: One More Seat
So I am in the process of installing some new steel re-pop fenders on a 34 sedan. everything matches up pretty nice except the very front stainless clip below the center of the radiator shell. Im not sure what it is even supposed to fit like? Are the fenders a tight fit all the way under the shell or do they fall away from the fender at the bottom? I can do what ever it takes. Not sure if the shell needs adjustment, the fenders need massaging, or ? Any help with past experience on this would be a great help and appreciated.
