34 Ford Gas Tank? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2010, 07:48 AM
34 Ford Gas Tank?
Morning,
OK... buiding a 34 ford with a SBC... I'm not running fenders and plan to "bob" the rear frame. Suggestions for a fuel tank? I've seen them in the trunk.. and the fill is inside the trunk. What do you guys suggest...
Sam
Old 03-22-2010, 08:35 AM
302 Z28's Avatar
Your only option base on what you have said your going to do is to place it in the trunk IMHO. Although I guess you could still use the fendered gas tank cover.
On my 34 I have full fenders but I did not want to poke a hole in the gas tank cover for the fill neck. I moved the filler opening of the tank to where the filler neck now comes up through the trunk floor.
Vince
Gas tank filler guba_unus General Rodding Tech 4 05-13-2008 06:47 PM
Gas Tank .... problems 63novawagon Body - Exterior 1 04-25-2004 11:26 AM
Gas Tank Plumbing Follow-Up Doc68 Engine 0 01-11-2004 07:28 PM
original 1936 ford gas tank fitting bomo General Rodding Tech 5 12-04-2003 04:20 PM
1936 ford gas tank bomo Body - Exterior 1 11-02-2003 11:26 PM
