Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '34 ford motor mounts
Old 08-18-2010, 01:01 PM
lamothe1's Avatar
lamothe1 lamothe1 is offline
I'm starting to put a 350 chevy small block in my '34 ford. I'm going to install a Heidts mustang ll IFS and side motor mounts. Right now i'm trying to figure out where to locate the motor mounts. it seams the cars I've looked at have the mounts kinda flush with the top of the frame rail. I would like to lower them about 1" as the trans (200r4) would fit better. If I lower the mount will it be more of a interference problem to get the steering connected from the steering column to the rack and pinion which is the forward mount type and does the linkage go over or under the mount?
