Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '34 ford motor mounts
Old 08-18-2010, 03:36 PM
lamothe1's Avatar
lamothe1 lamothe1 is offline
I'm using a mustang 11 IFS with the rack in front of the crossmember, so he angle of the shaft would be different than your '32 dropped axle. I wish I had the IFS installed. It would be easy to see where it goes, but I would like to scribe a mark on the frame where the mounts go than I could pull off the body and weld in the boxing plates, rear coil over mounts IFS and the mounts without taking off and putting on the body too many times
