Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '34 ford motor mounts
Old 08-19-2010, 06:38 AM
staleg's Avatar
staleg staleg is offline
Last journal entry: Hand brake
I have a chevy small block in my '34. Front suspension is a Fat Man M II.
I decided to move the engine up a bit compared to what the engine mount welding sheet suggested. Moved it enough to make the front crossmemeber the lowest point.
I personally think that's more important than if I have to use 2-3 or more universal joints on the steering linkage.
When I moved the engine up, the transmission cover for the 6 speed trans had to be made rather huge. So now it will be very limited space for all those 3 pedals...
But then again, limited space is what hot rod building is all about I guess.
