34 ford on s10 frame motor mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2005, 08:12 PM
jaxhome's Avatar
I purchased a 34 fiberglass ford coupe sitting on a boxed S-10 frame. For me to install a small block chevy engine, I'd like suggestions on motor mounts?
Old 04-03-2005, 09:43 PM
Wiki Edits: 49
There are small block conversion kits out there for the S-10 and I would think that would be the easiest way to go. Here's just one kit manufacturer: Allstar Performance
Old 04-03-2005, 10:15 PM
jaxhome's Avatar
Not an S-10 body
The 34 ford sits on the frame totally different than a stock S-10. I'm not sure if there will there be enough room between the engine and radiator to install a fan, alternator, etc. I'm hoping someone out there has done this conversion.
51 ford frame swap adam120674 Suspension - Brakes - Steering 8 02-27-2011 06:58 PM
Rusted '39 Ford frame sandman351 Suspension - Brakes - Steering 2 03-26-2004 10:52 AM
34 Ford Side hood grille/vent? Pilot34Coupe Body - Exterior 5 02-28-2003 07:15 AM
Mounting a 36 Ford PU on a S-10 Frame 36FordS-10 Hotrodders' Lounge 1 01-14-2003 07:23 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
