34 frame bent - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2013, 10:24 PM
34 frame bent
I have a couple questions about straightening my frame. first off I was thinking about putting some anchors in my garage floor . How many should I put and how far apart do they need to be ? The frame is bent in slightly at about the firewall and down a little in the same spot. I measured and its out of square almost an inch. Thanks in advance
Old 03-17-2013, 06:56 AM
Irelands child's Avatar
I absolutely believe that you would be better off with a body shop and a frame machine. They will get it straighter then Ford originally built it without crushing or distorting frame rails. Some of their equipment can exert a great many TONS(10, 20 etc) of pulling or pushing force with the right adapters to prevent unnecessary tweaks. If you can find an old time body shop that worked with cars with real channel frames, all that much better.
Irelands child
Old 03-17-2013, 07:42 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
The thing I question is if it is bent at the firewall,wouldn't you want to graft a undated front section on it anyways if not for nothing better braking??.
Old 03-17-2013, 08:08 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Guys you know you can buy a new set of reproduction 34 rails for reasonable. Replace the rails and you have a frame straight from the get go..
Sam
Old 03-17-2013, 08:09 AM
heres a pic
Old 03-17-2013, 08:14 AM
Wiki Edits: 3
http://static.speedwaymotors.com/pdf/916-57008.pdf
What you have is severely tweaked but you do have a lot of good stuff there..I would turn the job down if it came my way to straighten..new set of rails is the way to go on that deal...
Sam
Old 03-17-2013, 08:27 AM
are the new frame rails pre drilled for front, rear & center cross members ?
Old 03-17-2013, 10:45 AM
BigMo's Avatar
+1 on using a pro with a frame machine......but I also would go with new straight rails, cut and weld back in the cross members and such....make a jig or straight table to clamp the frame rails to and line everything up.....
Old 03-17-2013, 02:19 PM
Wiki Edits: 3
The new frame rails are drilled for all the stock parts including body mounts and such as they are intended for the fellow doing a restoration to original...So all you do is cut the rivets holding the old cross members and reuse those in the new rails. you may need to modify the center X member for mounts if you are building a hot rod. You will most likely split the wishbones to allow for the installation of a late model engine and trans..On the rear you will do that as well to allow for an open driveshaft and you will need to make locating arms for the rear.
Here are some images of 34 Ford hot rod chassis..Yours when complete will resemble some of these..
34 ford hot rod frames - Bing Images
Sam
Any more questions just ask...
Old 03-17-2013, 02:30 PM
I had a chance to work on it today I have it pretty close. Side to side is level and measurements are within a 16th. The frame rail is still pushed out on top a little cause it was smashed. Hopefully I can get it straightened out, its getting there.
ID:	72345   Click image for larger version
Old 03-17-2013, 02:45 PM
Wiki Edits: 3
That is good..I hope that you plan on boxing the frame to help keep it straight..
Sam
Old 03-17-2013, 02:49 PM
Sam
i do plan on boxing the frame I have a long way to go before I get there
bent frame rails Rosewood Body - Exterior 5 06-17-2010 08:01 PM
86 s-10 frame bent catscan4free Suspension - Brakes - Steering 3 03-27-2007 10:46 PM
bent frame eugeneragsdale Body - Exterior 13 01-27-2007 08:47 AM
Bent frame. BMM General Rodding Tech 4 08-14-2006 10:59 AM
bent frame bullheimer Hotrodders' Lounge 2 10-29-2004 08:25 PM
