34 Plymouth Streetrod with 700 R4 trans shift problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2012, 06:58 AM
Hello: I have a 34 Plymouth Streetrod with a 700 R4 transmission. The transmission was shifting ok until recently. The last time I took it out, the transmission would not upshift correctly. I had to have the RPM's around 3000 before it would shift from first and another 3000 RPM to shift from 2nd to 3rd. It will downshift OK, the reverse works and I checked the TV cable and it appears to be OK. Any help in this situation would be greatly appreciated. Nathan
Old 07-06-2012, 07:03 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders.com
I edited the thread title to place proper information on your problem. It helps the members and the search function of this web site.
can i use the 700-2-3 Shift Kit with the B&M Shift Improver Kit in my 1985 700r4 84chevyc10 Transmission - Rearend 8 01-16-2012 12:05 PM
1981 Jeep j10 trans shift & slippage problems jeep1981 Transmission - Rearend 1 07-14-2011 01:08 PM
2000 Lincoln Continental trans shift problems mbooom1 Transmission - Rearend 1 11-28-2008 05:19 PM
1984 Corvette 700 Trans Wont Shift Up billybonesmusic Transmission - Rearend 3 06-06-2006 08:23 PM
700 r4 shift kit NXS Transmission - Rearend 9 12-04-2004 11:34 AM
