340 6-pak idle issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2012, 09:18 AM
The 36 is finally on the road , can't count the hours getting this 6-pak user friendly but still have some issues, engine is stock 340 with factory 6-pak cam, stock carbs/linkage etc, factory choke and idle solenoid , she starts,warms and runs around in traffic great , however being a gearhead I do sometimes like to open her up on occasion, like the last couple of blocks before putting her in the stable , after having been at WOT for a bit the idle will jump to 1500-2000 rpm and stay there , put it in gear to slow and shut off , let it sit a bit and restart and idle is normal again. ??? , have checked for outboards hanging up , did notice once that the fuel levels were low after a quick blast so set about 1/3 siteglass on outboards and bottom of siteglass on center carb to no avail ( thought carbs were running low causing a lean condition) can't find any vacuum leaks, any ideas ???
Old 03-25-2012, 12:33 PM
LATECH's Avatar
Last journal entry: New Gas Tank
maybe double check the advance mechanisms, mechanical and vacuum. could be there and not the carb at all. I could be way off base, just a thought.
Could the metering rods hang up in the center carb?
Old 03-25-2012, 12:45 PM
4 Jaw Chuck's Avatar
Your mixture might be a tad lean on the center carb, have you tried turning the screws out a half turn to see if the condition reduces?
Outlawed tunes from outlawed pipes
Old 03-26-2012, 05:55 AM
I got it !!!, Hot idle compensator in center carb , bimetal operated valve , basically creates vacuum leak to speed up and theoretically help cool engine , being that we are cooled with electric fans , compensator will mess with my idle no more !!
Old 03-26-2012, 09:00 AM
lg1969's Avatar
Google "Tunnel Ram 406"
Make sure your secondary carbs are fully closed. It could cause idling go up if not closed.
Old 03-26-2012, 09:12 PM
Nice diagnosis, glad you found the problem!
Old 03-27-2012, 06:23 AM
Thank's Chuck ,I heard that Kohler had a new water conserving toilet , I thought i might try one and see if I can improve my mpg some !!!!
SBC 350 idle issues jwnova Engine 98 03-23-2012 06:19 PM
TBI 350 Idle issues...again... shane.,herold Engine 7 05-24-2011 05:27 PM
TBI Idle issues DoubleVision Engine 6 01-25-2011 08:36 PM
TBI Idle Issues DoubleVision Engine 5 07-23-2010 11:15 PM
Idle Issues trustyrustymudder Engine 2 05-19-2010 10:38 PM
