340 six pack Mopar manifold heat riser; block it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2008, 08:46 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Car is not a daily driver. The motor has a somewhat stiff cam, and the carb(s) has a cable choke, and mechanical outboard carbs. The carbs were once available from Chrysler as an "off road" part and I assume that's why they do not have vacuum controlled outboard carbs. The center carb is the correct one with smaller bores.
I am taking off the 4 barrel this week to put the tripower on, and looking for comments on blocking off the heat riser channel in the intake manifold.
The manifold is the high rise like on the AAR/TA but I took 1-1/2" off the top to lower the carbs so I can run aircleaners without cutting the hood.
Old 08-19-2008, 08:56 AM
Crazy Mopar Guy's Avatar
Tripower?
Are you a MoPar guy....? j/k
I would block it. Just make sure it's good and warm before driving, because cold drivability will suffer somewhat. I've done it a bazillion times. It doesn't give a huge hp increase though, don't look for any wild power claims to come to fruition IMO.
Old 08-19-2008, 01:37 PM
F&J F&J is offline
Yea, ok...sixpack
I'm a multiple carb guy
I already have cold issues with this motor. Since you brought that up, maybe I should leave them open while I try to get the motor sorted out on just the center carb.
Car sat for 10+ years in a dry barn and the guy who had it for 25 years has no idea what the speed garage did to the motor besides "souped it up". It has the Thermoquad, but no working choke. It starts horrible. It acts flooded right from the first crank, even if it sits for 2 months.
we are going to pull the motor for engine compartment cleanup/paint, but we want to get the engine sorted out first.
If I can't fix it, I'll be back with more questions
So far all I see is direct connection electronic ign added, some chrome....and what sounds like 'too much cam". I am not a cam guy, though. It is a 73 340 motor with the matching exhaust & intake manifolds. I don't know anything about the internals or head work, pistons, etc. It kicks the starter out before it fires, flames back through the carb, etc. The plugs are beyond cleaning & drying because it now won't even "clear out".
I'll report back. Thanks
Old 08-19-2008, 06:31 PM
F&J F&J is offline
This is as far as I got today..test fitting.
Where can I get an angled thermostat housing to clear the carb? The stock Mopars all seem to be pointing straight up?
The heads on this 73 340 have 360 casted in under the valve cover. Is this bad? Were the 73 340 heads better or worse? I wonder if the engine shop did a switch for an upgrade or downgrade?
I also can't find individual air cleaners....
and I need some push on breather caps for the Offy covers, but don't know what to ask for.
Big block S-10 a/c heat daily driver roadrash9r Engine 3 06-27-2007 09:11 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
Mopar Intake Manifold ?? 'cudabob Engine 5 09-27-2003 11:56 AM
Will a 400 intake manifold fit on a 1965 361 Dodge B block? CrashFarmer2 Engine 3 09-07-2003 09:53 AM
Small block Mopar roller rockers engineczar Engine 1 03-27-2003 03:18 PM
