347 stroker kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2009, 10:52 PM
72 grabber 51F-1 65 chevystang
347 stroker kit
I am going to start on the maverick in a month or so. It will be a strret strip car. I plan on building a 347 stroker for it. I am going to use a 1977 302 out of a van as the block. Not sure on what heads I will run I want Afr 185's but not sure I can afford a set. Any opinions on this kit would be appreciated. It seems like a good deal to me
http://www.northernautoparts.com/Pro...ctModelId=7517
Old 02-24-2009, 12:20 AM
techinspector1's Avatar
Wiki Edits: 326
Looks good to me. Save up for the AFR's.
Old 02-24-2009, 05:54 AM
67Mustang Al.'s Avatar
Hi,
The engine builder who has given me heaps of advice, has just put together a stroked engine using a bored and decked second hand block. The engine ran for an hour before seeping oil into the radiator. After a strip down the block was found to have a corrosion crack at the base of a cylinder due to the age of the block and lack of anti-rust used in the cooling system. Something to consider with a second hand block.
Cheers.
Al.
ford 347 stroker vs 351W Dubz Engine 12 07-07-2010 09:16 AM
351m Stroker Kit? RenoValron Engine 16 09-14-2007 10:42 PM
383 stroker kit "vs" YOUR INPUT 57NAPCO Engine 4 02-12-2005 10:01 PM
347 Stroker Silentlion_69 Engine 1 09-08-2004 09:45 AM
yeah they take a 350 block and get it ready for a 383 stroker kit 79 cutlass Engine 6 01-06-2004 06:53 PM
