Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 348/chevy -may have plugged exhaust??????
Old 01-03-2013, 11:31 AM
hcompton's Avatar
hcompton hcompton is online now
Old & Furious
Originally Posted by bsa_bob View Post
The kar is pretty rough but saveable. I hope the motor is as good as it looks. thanks for the tips bob s
What is the car doing when you try to start it?
Do you have spark and compression?
Have you tried starting fluid?
just an fyi if the engine started and was sealed shut in the exhuast it could reach 200 psi before it was choked out from clogged exhuast. At 200 psi the muffler will blow open and the pipes will split. So its a pretty good chance that is not the problem.
Tell us where your at pictures and all. We should be able to help a little at least. And pictures get people more involed when they can see what they are trying to help you with.
