| The Following User Says Thank You to BuzzLOL For This Useful Post: | ||
bsa_bob (01-06-2013) | ||
I am assuming it ran at one time so the cam chain is not off unless it jumped. Have you done a compression check? Just wondering if you got a hung valve.
I would replace all the tune up parts and try again. Wires, cap, rotor, points, coil and plugs. modual of its coverted to hei. Replace it all and turn the key either it will fire or you got another issue that needs to be tracked down. But with ignition out of the why its easy to find out what is left compression check and verify the plugs are actually firing. Then most of the problems are out of the way. A shot of either can rule out the carb in a few seconds. |
| Plugged Cat | CAMO KING | Hotrodding Basics | 11 | 03-17-2010 09:41 PM |
| all plugged up | tbelltim | Engine | 7 | 12-21-2007 08:06 PM |
| All Plugged Up | tbelltim | Engine | 1 | 04-14-2006 09:28 PM |
| Gas Tank Plugged | Granddad's51 | Engine | 7 | 07-14-2005 12:58 AM |
| Plugged Cat | Cruiseomatic | Engine | 5 | 09-12-2004 04:27 PM |
