35 Chev Master using 94 Ranger frame?
Looking for info about using a 94 Ranger frame (sgle-cab/short bed) for my '35 Chev Master.
Thanks-Mike |
Hi,,,,,,,
This has been chewed over a bunch of times,dont do it,re-inforce the original frame...
| The Following User Says Thank You to boatbob2 For This Useful Post: | ||
35ChevMaster (10-15-2012) | ||
'35 Chev Master-Ranger Frame Swap?
Basically wanting to have semi-modern suspension; uniform parts, plus the truck is a barter deal (if it makes sense.)
Had a bit of bad luck when an old hotrodder screwed up the installation of my stock Mustang front end. With that Mustang axle I also planned to use a 1980's Ford Ranger rear end. Finished all wood removal now with complete rocker panels (under-body), door skins, new (as stock) Suicide hinges. Body is off, body and frame stripped, sandblasted, now ready to mount on frame. Original frame is cleaned, painted, was ready for suspension. Throughout (past 12 years) I've searched for the BEST budget options since times are tough. Starting to think that a complete Fatman front end is the ticket. Trying to also use my brains to pick the BEST rear suspension for a "nice" ride; modern brakes, shocks, maximum handling. Have had thoughts about a four-point rear suspension??? Just figure this is the time to keep an open mind and NOT do anything crazy. Appreciate any good advice. Thanks |
I personally don't see a four link unless you plan on putting some serious power to the ground. A pair of parallel leafs is pretty hard to beat for all around driving and ease of installation. Brian |
This a '94 Ex cab frame. It could fit, but really not worth it.. Also note. '94 Front suspension is twin I beam which was introduced in the mid 60's. A system that works well, but is not the best
Ford Ranger rear end would have been a good idea 15 years ago, but now. Explorer rear ends are so plentiful and cheap, there is no reason not to use 1. 31 spline 8.8", disc brakes and they are only like 3 inches wider than the 83-'92 rears, and 1.5" wider than '93+ |
| Tags |
| 35 chev mster, body mount tips, frame swaps, ranger frame |
| ranger frame/32 desoto | 60 grit | General Rodding Tech | 3 | 11-04-2009 08:26 AM |
| frame swap:ranger to mustang | 53belair | General Rodding Tech | 7 | 12-27-2007 06:22 PM |
| Looking for frame specs for s10 and Ranger | Wooky71 | Suspension - Brakes - Steering | 2 | 03-30-2006 09:09 AM |
| ranger or S-10 frame swap ? | ron hug | General Rodding Tech | 2 | 10-05-2005 05:04 PM |
| Has anybody used a Chev Astro van booster/master cylinder for the 48 chev truck | tomy2tone01 | Suspension - Brakes - Steering | 2 | 04-07-2003 05:05 PM |
