35 chevy mustang II install - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2008, 01:14 PM
I am wondering if someone could advise me as to how a tubular lower control arm should line up with the crossmember.
Old 01-05-2008, 01:39 PM
dinger's Avatar
I;m going to move this to the suspension forum, I think you will get more response there. Dan
Old 01-05-2008, 07:41 PM
Wiki Edits: 49
Tubular or stock the lower control arm should be level with the crossmember which hopefully is level with the ground. That's with weight on the suspension.
Old 01-05-2008, 07:54 PM
Cape Cod Bob's Avatar
did u get brackets for the CA's to weld to the frame.
I welded mine on so they will be no lower then the xmember when the lower a arms are level with the bottom of the xmember, which is where everything should be with the car completed. 1931 chevy
Old 01-06-2008, 03:04 AM
Thank you all for replying to this question. I am wondering about the position front to back of the lower control arm. If I make it equal distance with the sides of the cross member (which I think would be right because the spring would be riding up and down right next to the crossmember) then I have to put a spacer in the front and the back both to get this centering. The front spacer is about 1/2 to 3/4 of an inch long and the back spacer is about 2 and 3/4 inches long. Would this be right? Also has anyone installed a Heidt crossmember and spring tower on a 34/35 Standard Chevy frame? To answer Cape Cod Bob, I got gussets to weld the back spacer to the crossmember. Is this what you are refering too?
Old 01-06-2008, 08:57 AM
AntnyL's Avatar
The position of the lower control arm depends on the relationship of your spindle vs. the wheel opening. I would mock that all up (including the upper control arm) to determine where it should be.
On my TCI MII front suspension, the lower control arm has a full-length tube that acts as the spacer, positioned flush at the front (basically, no spacer on the front), and protrudes about 3" to the rear to act as a spacer. That 3" protrusion is gussetted to the crossmember.
Hope this helps. if not, let us know.
Antny
Old 01-06-2008, 09:44 AM
I have a picture of how I think the lower control arm should look like in regard to the crossmember. What do you think?
Old 01-06-2008, 10:45 AM
AntnyL's Avatar
That relationship looks right; the spring perches should be centered on the crossmember as in your photo.
Antny
Old 01-06-2008, 11:13 AM
Thanks, that helps. I am now trying to get the upper spring tower at the right height and at a 3 degree angle. I will let you know. Thanks again.
Old 01-06-2008, 05:16 PM
How much adjustment should I allow for on the upper control arm? The upper spring towers are only tacked in. I have only got one degree negative with the upper arm pushed in all the way. I have pictures.
Name:	upper arm in all the way.JPG
ID:	26704   Click image for larger version
Name:	lower_control_arm at 90degrees.JPG
ID:	26705   Click image for larger version
Old 01-08-2008, 04:09 PM
Twisted Minis's Avatar
A different breed
Last journal entry: New Truck
A single degree of negative camber is perfectly acceptable. That is more or less what you want for a street driven vehicle. However, you want your camber to be at -1 at your loaded ride height.
Old 01-09-2008, 05:29 AM
Bluejackets67's Avatar
I would suggest calling the manufacturer of your kit.
I would expect to have some more room in the upper mounts. Once you get your camber set, you'll need to bump the back in a little farther for the caster setting.
Astro column /shaft on Mustang II rack? staleg Suspension - Brakes - Steering 1 03-02-2007 11:52 PM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
Chevy II Mustangsaly Hotrodding Basics 18 03-09-2006 05:11 PM
changing manual steering to power on 63 Chevy II Mustangsaly Suspension - Brakes - Steering 10 07-19-2005 04:21 PM
Mustang II in a '40 Chevy sedan noxqsz Suspension - Brakes - Steering 4 06-28-2005 12:35 AM
