35 Chevy Sedan Rear Axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2012, 04:01 PM
I am thinkin about starting my 35 chevy now and curious what a great rear axle would be for the car and any tips for it.
Old 07-14-2012, 10:18 PM
Canzus's Avatar
a red wool sock on his dinger
Could you be a little more vague,
Need more info to give a sensible answer...
What engine?
What transmission?
What is the expected weight?
What is the end use?
What size tire?
_______________________
Steve& the Rockette
Too many toys to list...
Old 07-14-2012, 10:24 PM
Its gonna be just a street rod. Its gonna have just a 350 with possibly a turbo 350 trans. i have an s10 axle for it but i just wanna hear from someone who might have some better insight for it. as for wheels not sure yet probably 16 or 17 inch rims
Old 07-17-2012, 05:00 PM
I like for the rear wheel bolt pattern to be the same as the front wheels.
Most rodders prefer a 9 inch Ford rear end. Strong, easy to find parts and easy to work on.
Here is a on list of rear widths ...
65-66 Mustang 57.25 inches
67-70 Mustang 59.25 inches
71-73 Mustang 61.25 inches
77-81 Versailles 58.50 inches
74 Maverick 8" 56.50 inches
75 Mustang II 8" 57.00 inches
67-73 Mustang, Torino, Ranchero, Fairlane 9" 59.25 inches to 61.25 inches
57-59 Ranchero and station wagon rears, 57.25 inches
66-77 Bronco 9", 58 inches
77-81 Granada/Versailles, 58 inches
67-71 Comet, Cougar, Mustang, Fairlane, 59.25 inches
71-73 Mustang, 61.25 inches
64 Falcon 58 inches
67 Cougar 60 inches
67 Fairlane 63.50 inches (coil springs)
72 Ford Van 3/4 ton 68 inches
73-86 65.25 inches
57-59 Ranchero and station wagon 57.25 iches (narrowest 9" housing)
66-77 Bronco 58 inches but has 5-on-5 1/2 inch diameter bolt circle
67-73 Torinos, Rancheros, Fairlanes 59.25 inches or 61.25 inches
67-71 Comets, Cougars, Fairlanes 59.25 inches
Where to find the 9" rear axle
67-73 medium and big block Mustangs and Cougars
66-71 Fairlanes, Torinos, Montegos, Comets, and other Ford intermediates
with big blocks
57-59 V8 Fords and Mercurys
77-81 Lincoln Versailles & Trucks
Type of 9" axle housings
67-73 Mustang/Cougar - light duty, thinnest housing material, small axle
bearings, 28 and 31 splines
57-68 passenger car and 1/2 ton truck - medium duty, stronger than Mustang
type, 28 and 31 splines
Ranchero/Torino - heavy duty thick wall housing, 3.25 inch diameter axle
tubes with flat tops
69-77 Galaxies (coils), Lincolns (coils), and late pickups (leaf)- 3.25
inch diameter all the way to the backing plate, coil housings have upper
control arm mount
How to recognize 9" housing centers
57 - no dimples, flat center band up the center of the rear cover, bottom
drain plug
58-59 - two dimples on back of housing, flat center band, some had drain holes
60-67 - two dimples, flat center band, oil level hole in back cover
63-77 Lincoln, LTD, Thunderbirds had 9.375 inch centers, housings were cut
away at the gasket surface for ring gear clearance, one curved rib at the front
top portion of differential. Strong, but no gears.
Types of 9" Axles
28 spline axles cannot be shortened and resplined (they're tapered)
Some can: 69-73 Mustang and Cougars have a straight 28 spline axle.
72 and earlier 31 spline axles have the ability to be shortened
73 and later 9" (big cars) have a 5-on-5 bolt circle and the axles cannot be
shortened
67-73 Mustang axles identified by wheel flange:
I always use a 9 inch Ford under my projects. I dislike the spicer type/bolt on rear cover rear ends ...
Old 07-18-2012, 01:27 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
Not sure how wide the leafs are spaced on the 35 but the S10 might bolt in but prolly not very strong. Might look at a Camero/Firebird 8.5 or 12 bolt also.
Old 07-19-2012, 05:52 AM
Oh i know s10 axles are strong enough i had an s10 and had 1 1/2 ton of feed in the bed n never broke it
1956 Chevy sedan rear end gear ratio? goodold56 Transmission - Rearend 3 02-28-2011 07:11 PM
'31 Model A Tudor Sedan Rear Axle sgo70 Transmission - Rearend 5 07-07-2008 06:10 AM
'36 chevy sedan rear suspension Caddad65 Suspension - Brakes - Steering 3 12-14-2007 08:07 PM
'86 Caprice Sedan: 7.5 or 7.625 rear axle voodooracer Transmission - Rearend 29 11-06-2007 05:37 PM
