35 ford pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2012, 09:39 PM
Post 35 ford pickup
I have a 1935 11/2 ton that i am converting to a pickup. The cab,hood and grill shell is the same. The finders are 2 1/2 in. wider and do not role down as much as the 1/2 ton. The front of the fender is also different as it has a notch in it to set down over the bumper bracket. The frame is 5 in. wider on the 1/2 ton or car frame. The cab mountson the outside of the frame of the1 1/2 and on the top of the frame of the car frame. The frame is the same on the 35 36 37 38 39 40 car and 1/2ton pickup. You dont have to box the frame on the 1 1/2 as it is much bigger and thicker but you need to notch and c brace for therear to set down. I f you need more info you can call me at 573-718-6351 Stan.
Old 11-13-2012, 09:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders...
You posted to a 10 yr old thread. Thanks for the information.
Also, it is a bad idea to post your phone number on open forums since spam bots will find it.
36 Ford Pickup on a Ford Ranger Frame? Fasteddy General Rodding Tech 21 12-08-2012 12:25 PM
35 ford pickup tired38 Body - Exterior 0 12-15-2009 05:54 PM
35 ford pickup bobs Suspension - Brakes - Steering 5 12-30-2002 06:06 AM
1932 Ford Pickup and 1933-34 Pickup Different? YES pasadenahotrod Transmission - Rearend 1 10-23-2002 03:20 PM
48 ford pickup I.F.S. pickupman Suspension - Brakes - Steering 2 06-10-2002 05:00 AM
