35 Ford Pickup cab and frame width?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2006, 11:12 PM
Super Chevy's Avatar
BRB carring
Im building an open wheeled hotrod, I only have a frame right now but I'm on the hunt for a body. I really really want a 30-34 ford pickup cab but I can't find one anywhere. I just found 4 other cabs tho, two 35 ford cabs and two 36 ford cabs but they are 5 hours away. I'm worried that these cabs are going to be too big and might not look right with no fenders. My frame has a maximum width of 43.5", it was origionally under a 30 Model A Sedan and it uses 34 ford rails..
Here are my questions:
Does anyone on here know how much bigger a 35 cab is compaired to a 34?
What is the maximum width and minimum width of a 35 cab?
How long is a 35 cab?
What is the width of a 35 frame from the outside of the frame rails?
If you guys could help me out that would be great!
thanks
Once you go flat black you never go back.
1966 El Camino
1992 Dodge Shadow
1986 S-10 Blazer 4x4 Hot Rod
1970 Chevelle
1966 Chevelle 4 door
Home Made Go Cart
Old 03-01-2006, 07:17 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Here is a link to Wescott's (you can get Frame dimensions there)-I don't think the '35/36 Body will fit a pre'35 without major modifications, but I might be wrong-good luck, IMHO, '35/36 Ford Trucks are beautiful if done correctly.
http://www.wescottsauto.com/site2003C/frame_specs.html
Old 03-01-2006, 09:19 PM
BRB carring
thanks for the link! the body is getting channeled over the frame, so everything is just going to be fabricated.
can someone on here please measure the width of their cab at the back and at the fire wall?
thanks!
1966 El Camino
1992 Dodge Shadow
1970 Chevelle
Home Made Go Cart
Old 03-02-2006, 07:50 AM
I have what is supposed to be a 35 pickup frame. There are some differences in the center crossmember area but as far as the overall dimensions (width and length) it is identical to a 33-34 Ford car frame. I'm just not sure what the 33-34 truck frame looks like. Hope this helps.
Old 03-02-2006, 11:10 PM
BRB carring
thats exactly what i wanted to hear, thanks. now i just gotta drive 5 1/2 hours to get the body...
1966 El Camino
1992 Dodge Shadow
1970 Chevelle
Home Made Go Cart
Old 01-18-2009, 03:12 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
This above link has been changed to a PDF file and has a new link, there is also measurements for 1926 to 1941 Ford frames. The new link is as follows:
http://www.wescottsauto.com/Tech/frame_specs.html#howto
Old 01-19-2009, 12:36 AM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
35 to 40 car frames and 35 to 41 truck frames are all the same except truck frames dont have the 4 body mount plates on the outside. I Googled 35 Ford truck rat rod last night and came up with a bunch of images of fenderless trucks and I think they look great. I have all my body parts so I will use the fenders on my project althought it is tempting to want to build it old school like you suggest. Sorry cant help with the cab specs, its in the corner of the garage buried under a mountian of parts.
55 ford coe frame swap cab over big jer Suspension - Brakes - Steering 1 05-10-2012 12:13 PM
1936 Chevy pickup cab wood referbish donlp Body - Exterior 6 12-14-2010 04:27 PM
'40 Ford Pickup cab mounts alittle1 Hotrodding Basics 5 04-03-2004 06:41 AM
40 Ford Pickup Body Parts enemyace Body - Exterior 1 03-23-2003 10:54 PM
