35 Ford Suspension
My 35 Ford has a Heidt's M II front suspension with stock shocks and 57 Chevy rear springs with a dearched main and air shocks. While front and rear push down and rebound nice and the ride is really isn't all that bad, I think it could be better. The air shocks only have 60 lbs and installed because I am thinking of pulling a small travel trailer or travel with a full load of passengers.
Advise is all over the place concerning ride using dearching vs lowering blocks and air vs coil over. I was considering replacing front shocks and springs with air bags and replacing rear air shocks with Bilstein coil over shocks. What I'm looking for is those commercials where the car stays level and the suspension is taking all the bumps. Am I dreaming trying to make a silk purse out of a sows ear. |
In a word....YES! You didn't mention what body you have but by the "full load of passengers" comment I guess we can eliminate everything but Tudor or Fordor Sedans, can't we?
Do you have bottoming problems with rear suspension as it is without the air shocks inflated, i.e., are you using the air shocks as suspension rather than bounce dampeners? Is this a problem with 2 passengers as well as 4 or 5? If so, you made a mistake in the design of your rear suspension, not enough spring for the job. |
35 Ford suspension
It's a two door sedan. I think it would bottom out without the air shocks but it has 5 new leafs now althought the main was dearched. I ran this system for 15 years until I tore the car apart 12 years ago. Actually I had 6 in the car including one really heathy young girl and it seemed to ride better and with only me on a smooth road rides good. It is a old car with mix matched parts and maybe I'm expecting too much. Takes alot of trial and error to get all the stars in alignment. What's your thoughts on dearched springs vs lowering blocks?
35 Ford Suspension
Thanks for all the input. Air ride seems the way to go but will take some design work on the rear since the guy put the springs on the outside of the frame since the 57 Chevy springs were so long and I never changed it. I think I'll get a kit to mount under frame to get rid of the dearched springs. Deep down I never really thought that was the way to go. Don't ask me why I did it.
35 Ford Suspension
Do you have a web site or phone for A.R.T. Thanks
| 1977 Ford F100 Suspension, Lowering, Steering | sbilbrey | Suspension - Brakes - Steering | 9 | 03-08-2008 11:10 PM |
| '29 Ford Model A Suspension | jfarneti123 | Suspension - Brakes - Steering | 4 | 11-29-2005 11:14 AM |
| ford 35 coupe | gunnulf | Hotrodding Basics | 2 | 09-19-2005 04:27 PM |
| Rear Fenders for '35 Ford Tudor/Fordor | '35 Sedan Delivery | Body - Exterior | 13 | 08-03-2005 07:47 AM |
| Front Suspension 53 Ford Front Clip | PaulNJ53Ford | Suspension - Brakes - Steering | 2 | 08-11-2004 10:12 PM |
