I searched similar threads but dont find the answers I'm looking for. I see the 2 drain holes in the corners of my windshield opening but I dont find the two 1 1/2" tubes that connect to them. I assume they rusted off. I cant find any drain hole leaving the cowl either - may have been obliterated in the sheet metal repairs. My question is could I just seal off those holes off without any major problems? It seems to me that, even with the drain tubes, leakage could occur where the crank out mechanism comes from the body. Good news is the vent drain seems intact. Thanks
I believe the drains are there so that the inner channel doesn't collect and retain water, and therefore cause rust-I would try and replace them. Wouldn't steel fuel line work, say 1/4"?
Probably would but I dont know how I'd attach it. All there is there is the hole, and unless you pull the dash out(not happening) I dont see how you could weld/epoxy whatever the tube to the windshield.
That is a good point. When I was building my car I spent a lot of effort to design a drain system for the deck lid. It all seems ridiculous now, since the car never sits outside and I never drive it when it even looks like rain.
The original drain tube was a flared 1/4" steel tube (gas line stock) and it was soldered in place. The 1/4 inch drain lines were connected to a metal T and connected to another T that had the drain tube from the cowl vent seal track and then went thru the firewall and dumped down onto the bell housing. I have seen the wind shield drains routed behind the kick panels and out the side of the toe board side support below the toe board. I would install them because you do wash your car on occasion and you don't want the water standing trapped by the windshield rubber. That is why you no longer have drain tubes because over the years, they plugged and could not drain any longer.
thanks - I'll probably just dry out the windshield with a rag if I wash it or get caught in the rain. It would be quite a project to solder in new tubes. I'll run a hose from the cowl vent and hope my feet stay dry.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
