35 windshield install help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2011, 05:01 PM
Last journal entry: Con't
Got all new glass for my 35 ford tudor. Everything went well until I got to the windshield. I got bedding tape from mac's, and cleaned frame thoroughly and painted it. I've got the two halves within 1/2 inch of being together and I cant get them any further. I'm afraid I'm gonna break the glass. Does anyone have any tips/ suggestions?
Old 03-10-2011, 08:15 PM
painted jester's Avatar
Last journal entry: no big deal
Glass
Man I'd like to help you, I've put em in before (but its glass theres so many things that could happen ;some times glass comes a hair off and has to be ground a little !! I would call a mobile glass co . you have every thing done , and your there to help, they wouldnt charge you much (just make sure the guy they send knows early glass) I would have too be there!!! Good luck!! And if they brake it they buy new
Old 03-11-2011, 06:36 AM
thank you, Chip
Old 03-11-2011, 11:28 AM
dinger's Avatar
That is a one piece windshield, I believe. Google images, I don't see any 2 piece Ford Tudor windshields.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 03-11-2011, 11:52 AM
nope - 35's are 2 piece
Old 03-11-2011, 03:52 PM
302 Z28's Avatar
I remember replacing the vent window glass on Ford trucks. We would get about 3 feet of bedding tape and wrap the edge of the vent window, slid it into the vent window frame and smack it with a rubber mallet until it seated. It always made me a little nervous, but I never broke one.
Vince
Old 03-11-2011, 06:09 PM
35terraplane's Avatar
I believe fords first 1 piece was in 1952.
Bob
Old 03-11-2011, 06:25 PM
dinger's Avatar
I can't find a picture of a 2 piece windshield, stock or modified
http://www.google.com/images?hl=en&s...&aqi=&aql=&oq=
Just got out my bible on the 35-36 Fords, windshields are the same for both years, with the exception of the cabriolet and the sedan convertible, they were fixed windshields and had different trim. ONE piece. 37 appears to be 2 piece. My 36 is a one piece.
Old 03-11-2011, 06:47 PM
My books show a one piece! I never thought of that last night, and I once owned a 35!
Old 03-11-2011, 06:49 PM
Can you post a picture! Did you take a two piece out?
Old 03-11-2011, 06:57 PM
I took this original frame and glass out of my 35 ford tudor - It is 2 piece with trim clips over the joint. I dont have any pics handy, but if you check a post by Brigrat on12/4/2010 titled "1935 1936 ford coupe sedan front windshield frame" he has a good pic attached.
Old 03-11-2011, 07:12 PM
Thats the frame I thought you ment glass get your glass trimmed ,youll be all set, take your frame and glass with you to the glass shop !!!!
Old 03-11-2011, 07:19 PM
Dinger said it was a one piece winshield (it is ) you said it was two piece thats the frame not the windshield !!
Old 03-11-2011, 09:51 PM
dinger's Avatar
http://www.speedwaymotors.com/1935-1...rames,775.html
http://www.oldbleu.com/notes.htm
Old 03-11-2011, 10:19 PM
35 winshield
Maybe I should have wrote what I was thinking, must have had some brain fade.
From the Model A to 36 was all flat glass, Then in 37 they went to 2 piece glass until 1952.
Dinger is right hands down.
Bob
Install V-Butt windshield spanky36 Body - Exterior 4 02-28-2009 02:39 PM
Windshield install? on 41 chevy coupe 41CHEVYCOUPE Body - Exterior 1 08-14-2006 08:54 AM
68 suburban windshield install anthony h Body - Exterior 1 02-09-2004 05:13 PM
windshield install CARGUY Body - Exterior 2 12-28-2003 10:55 AM
flush mount windshield install n3ffn Body - Exterior 6 10-28-2003 04:49 AM
