350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2012, 10:04 AM
I have a 350 block that i want to make a street car but i don't want to make a 383 of it. from what i here it cost more money and its harder to work on but i don't know. what can i do to it for some power.
Old 05-23-2012, 10:12 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Skies the limit, intake upgrades, cam, exhaust. What's your budget and what's your goal, hp level, what car is it going in, what trans, etc.? Most of all, what's your budget, it looks like maybe relatively low?
Semper Fi
Old 05-23-2012, 09:59 PM
Ok please consider the following:
If you CAN do engine work do these:
-Camshaft (Good timing)
-Flattop pistons
-Distributer
-Intake Manifold
For low end stuff: (Get all these from Summitracing.com, amazing prices! All these proces are from summit.)
-Headers ($150)
-Cat delete
-Aftermarket exhaust ($300)
-Quadrajet Carb (Will save gas too ) (Buy one used and rebuild it if you can)
-KN Air Filter/Cleaner ($45)
-Spark Plugs($10-50)
-Spark Plug Wires( $50)
-X Pipe for the exhaust system (Can build yourself)
-Change out rear gear to high 3's ($200ish)
Thats my 2 cents
All a matter of how big your pocket is!
From the spark plugs though you wont really notice much power just FYI
Old 05-23-2012, 11:12 PM
American Muscle's Avatar
305 Turbo-Fire 240hp
Vortec heads, matching intake, summit 1103 cam kit. and the above mentioned mods. 300+hp at the least
Old 05-24-2012, 01:25 AM
Do you have only the block?, no crank or rods?
Old 05-24-2012, 03:36 PM
thanks everyone. and yes i have block with just about everything in it
350 sbc with t-350 Trans, size of bolts to blockneeded? Canuckcamaro Transmission - Rearend 2 03-10-2011 07:46 PM
351 Windsor: minimum 350+/350+ with stock crank,rods and heads? BB72R-Yes Engine 5 07-20-2010 09:18 PM
Wich heads do you recommand for OFFROADING -305 or 350 on a 350 engine? offroader9 Engine 1 04-07-2010 02:07 AM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 01:44 AM
I have a turbo 350 behind a 350 4bolt main in my 65 Imapala. It shifts into first an shepardb Transmission - Rearend 5 02-19-2004 03:41 AM
