350 ???
I bought a 68 firebird when purchased I was told the engine was a 350 rocket but the engine code is 488986 which came back as a pontiac is that correct and is it a small block or big block
350 ???
According to this website it is a 1974 Pontiac 350. Pontiac Engine Block Casting Numbers
It shouldn't be a 350 rocket unless someones modified it. The 350 "rocket" would be an Oldsmobile engine and the only f-bodies that got Oldsmobile v8s were the late 70s Firebirds that got the 403 Olds instead of the 400 Poncho. I don't think any Pontiac motor follows the "convention" of big and small block. Technically an Oldsmobile doesn't either, they just have motors with a taller deck height, thus making them the "big blocks". FWIW i think there was a couple "short deck" ponchos like the 301. I'm sure one of our resident Pontiac experts will chime in.
does anyone know which type heads I need for this moor
Until a Pontiac enthusiast stumbles across this thread or a mod decides to change the title to something more specific, here's something to get you started:
Cylinder Heads Just as a suggestion, next time try to make your thread title more specific like "350 Pontiac" or something the like. The fact that it only says "350 ???" is probably making many people believe that this is a thread about a SBC 350, which is obviously the most common and popular engine of this displacement. |
| 350/350 set up in a questionable car.(1956 oldsmobile) | Mike Hateful | Hotrodding Basics | 11 | 09-17-2011 09:46 PM |
| 351 Windsor: minimum 350+/350+ with stock crank,rods and heads? | BB72R-Yes | Engine | 5 | 07-20-2010 08:18 PM |
| Wich heads do you recommand for OFFROADING -305 or 350 on a 350 engine? | offroader9 | Engine | 1 | 04-07-2010 01:07 AM |
| DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. | Steve-0321 | Hotrodding Basics | 21 | 11-26-2007 12:44 AM |
| I have a turbo 350 behind a 350 4bolt main in my 65 Imapala. It shifts into first an | shepardb | Transmission - Rearend | 5 | 02-19-2004 02:41 AM |
