350/290 GMPP Engine Build need advice(cam, intake etc) - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2010, 06:56 PM
Chevyboy_0's Avatar
Diesel Fuel Abuser
Hey guys, its been a while since ive posted last but now I finally have a new scheme
I recently purchased a good set of 041X heads for $25.00 Right now they are disassembled and in the process of being cleaned. Being that these are 64cc chamber heads and will be decked to remove a slight (about .003") dimple in one of the heads it will be a bit different compression wise from the 76cc heads that are on the motor now.
So before I get ahead of myself let me tell you what i am working with. Currently I have the GMPP 350/290hp crate motor. For those of you who arent familiar with this set up it is a 4bolt main, 350, with 76cc chamber 1.94/1.50 heads, the rods are Powdered metal, and the pistons are "dished"(no matter how much searching I have done i cannot find the actual amount of dish they have...) so out of the box the Compression is advertised at 8.5:1 although i have talked to a few guys and they said the actual CR is closer to 8:1. The cam is a .450"/.460" Lift 222*Intake 222* exhaust @ .050" duration with a 114* centerline.
The Heads that I purchased are a pair of 3947041X Heads, my plans for them are new valves, screw in studs and guideplates, new springs, hardened seats, bronze guides, decked, and 1.6:1 roller rockers. When i put the new heads on I would also like to change the cam, intake, and carb to utilize the modifications.
Seeing as I have never fully rebuilt an engine this way before I figured i could ask for some guidance and advice from more experienced builders/members. I would like it to have a nice lopey idle and crisp throttle response. But keep in mind that this is a budget build and it will not be run on the track very often if at all.
Thanks for bearing with me on this long post.
Andrew
Old 08-25-2010, 08:24 PM
bigdog7373's Avatar
Of course it's fast
You're going to want to make sure the heads can handle the extra lift that a larger cam and 1.6 rockers will provide. Also make sure you have strong enough springs so you dont get valve float with the extra lift.
Old 08-26-2010, 12:20 AM
Chevyboy_0's Avatar
Diesel Fuel Abuser
Being a new guy to engine building how do I go about checking to make sure the heads can handle the extra lift?
But as for the springs and such summit sells a kit that includesall the necessary stuff to install a bigger cam(springs, retainers, locks, etc) the kit is said to be good up to a .550 lift.
Also would someone be able to give me an idea ofwhat to expect CR wise?
Old 08-26-2010, 08:18 AM
bigdog7373's Avatar
Of course it's fast
Need to know piston volume, deck height, head gasket thickness to calculate cr.
Old 08-26-2010, 12:32 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
i can give you a rough estimate on what the compression will be, and yes from my experiance with the GMPP 350/290 motors they are acually inbetween 7.9:1 and 8.2:1, so taking 8.1:1 (avg) with 76cc heads and lowing them down to "64cc" which these heads are typically about 66cc and then milling them .003" which will only take off about 0.5cc (.006 = about 1cc) you will be working with about a reduction of 76-65.5 = 10.5cc and for about every 8cc's you will gain about a full 1 point in compression. so based on 8.1:1 i would say you would end up with around 9.3:1
as for a cam i would stick to one that is similar to the one that was in there, about 220-225 duration @ 050, 270-278 advertised duration, 110LSA, and closer to a 106centerline, lift around .460-.480
383 engine tapping and oil burning- weird RowShan Engine 15 10-10-2009 06:07 PM
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 02:10 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
setting roller rockers Thacolbster Engine 2 02-07-2003 07:48 PM
GMPP CRATE MOTOR Intake Manifold Vacuum alligator Engine 6 09-18-2002 08:02 PM
