350/300 Corvette rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 01-28-2010, 10:54 AM
TWINRAY's Avatar
Hey buddies,
I'm here today to learn what are the best heads, roller cam/lifters and maybe a new intake (if the stock hood will still fit) for my 1969 Corvette that I've had since 1973. I'm putting a stock nose back on it after having a custom nose since 1974. None of that tri power, solid lifter krap ( ) for me, it's got the base 350, putting out 300 gross with an TH400 and a 3.08 rear. So, it's bottom end grunt is what I'm looking for. I'll be back at 'ya after I get my feet wet reviewing some posts.
Fred
Old 01-28-2010, 11:39 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site Fred, Post your question in the engine section and someone will help you out. Not everyone checks the intro section.
Cole
Old 01-28-2010, 02:18 PM
TWINRAY's Avatar
Will do Cole,
First I want to get a general idea of what I think I should get. A hydraulic flat tappet cam would be easy but I want a few more hp that the roller set up should give me plus I won't have to worry about wiped out lobes.
Regards, Fred
Old 05-20-2011, 10:33 AM
TWINRAY's Avatar
Just noted I haven't updated you guys of my progress (or lack of) on my project. I have put my original motor "on the side" and bought the 355 hp (base model) ZZ4 to put in. Since I want to do "some drivin'" when I get it done, I figured this might be the best option. My car has only the 3.08 rear so this engine has good torque, down low, which I need. I'm trying to figure out who/what to do regarding the TH400 rebuild.
ID:	55442   Click image for larger version
ID:	55443   Click image for larger version
Old 05-20-2011, 04:08 PM
eloc431962's Avatar
Wiki Edits: 37
Looking good Fred i have been there you have brought back some old corvette build memories thank you for that
Cole
1977 Corvette engine rebuild etaylo17 Introduce Yourself 1 07-18-2008 08:34 PM
1987 L98 Roller Corvette engine,Noisy valve train after rebuild.... Calderone Engine 9 04-24-2008 11:03 PM
Corvette Summer Corvette Front Clip MADTECH72 Body - Exterior 18 04-16-2008 08:45 PM
700r rebuild kit - best one? mattson70 Transmission - Rearend 13 04-10-2007 07:00 AM
4L60 rebuild possable? fumplet Transmission - Rearend 11 09-13-2006 12:27 PM
