350 with 305 head - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2013, 01:06 AM
350 with 305 head
I have a 350 that I want to put 305 heads on how much of a difference does it make. And I am making it carberated but I cant put a mechanical fuel pump on it like the 305 has so how can I do this
Old 10-13-2013, 02:38 AM
Proud LOSER
Search button is your friend
305 head on a 350 sbc
Sbc 350 w/ 305 heads..
305 heads put onto a 350 sbc block
305 heads or 350 heads on sbc 355
chevy 305 heads on a 350??
I need help building a 350 using 305 heads
350 sbc with 305 h.o heads will this work whats the ups and downs
That's just page one....of this site....
Old 10-13-2013, 07:06 AM
jokerZ71's Avatar
Wrench Turner
Which 305 heads specifically? On certain 305 heads,the small valves & flow will kill any power gain from the CR increase w/o major work & porting.
The Following User Says Thank You to jokerZ71 For This Useful Post:
1Gary (10-13-2013)
Old 10-13-2013, 07:36 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Exactly.This 305 thing being popular doesn't make any sense when you spend money on everything else and then cheap out on one of the most important things the heads.
Old 10-13-2013, 07:44 AM
jokerZ71's Avatar
Wrench Turner
As far as the fuel pump,you can install an inline electric pump.If you now have an intank pump,you will have to modify or change your pickup assembly & depending on which carb & pump you use,you will prolly need an adjustable fuel psi regulator (AFPR).
Old 10-13-2013, 09:37 AM
techinspector1's Avatar
Wiki Edits: 326
Please tell us what it is exactly that you intend to achieve with a head swap.
Old 10-13-2013, 07:47 PM
spinn's Avatar
I put the 58cc head on the parents lesabre. The tight runner, higher compression, and small valve gave increased velocity. You could get that car to fry the tires, and be done by 4000rpm or so. That wasn't a big deal cause they shifted to second at around 4200 rpm. A 4200 redline, that's like todays diesel . I got the idea from a friend who did the same thing. Those 70's cars sucked. I mean I love them, but they were junk.
Old 10-13-2013, 08:50 PM
I have a pair of 601 heads that are ported and are fitted with 2.02 1.6 valves
I think they're great, but even with my xe 274h cam they don't like to be reved past 5800
Old 10-13-2013, 08:58 PM
Proud LOSER
I have a set of pretty heavily worked on 416's on a stock smogger 350 with a shim headgasket, small lunati cam, qjet Carb, and mid length headers to sidepipes and it goes consistant 13:20's with 411's and a TH350 in a C3.
With enough time and effort I think they are a great budget/junkyard small block choice.
You get out what you put in.
305 head on a 350 sbc Trav Engine 41 04-13-2013 08:30 AM
14102187 casting 305 head modification,outperform a 350 head ??? Calderone Engine 3 05-10-2009 09:09 AM
305 & 350 Head Gaskets the Same? oscarlovel Engine 13 01-28-2007 05:40 AM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
305 head on 350 Houman SS '70 Engine 11 02-02-2005 05:51 AM
