350 with 327 double hump heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2006, 01:54 PM
ok,im thinking about getting a 350 stock motor from a 68 gmc truck, puting 327 double hump heads,eldobrock intake preformer,elgin pro stock camshaft,with306-307int.lift cam l l lift,valve lift,int..450 ex. lift.460,mallory breakerless ignition. dynomax headers.i want to get 12 bolt rearend out of the old truck and find an old chevy II. or s10 . is this a good idea for a project any help would be great. the truck has a 4 speed manual trans.
Old 10-16-2006, 03:39 PM
The truck 4 speed will not work in a car. 1st gear will be a granny gear and the shifter comes up in the wrong position.
There are much better heads than the old double hump heads. The aftermarket has really made big gains in cylinder head technology. Plus those old double humps do not have any accessory holes and need harden valve seats to run unleaded fuel.
I would just use a HEI distributor with a msd conversion kit. Those Mallory's are prone to fail, in my experience.
Nothing really special about a 68 truck differential. In most cases it is just a regular 12 bolt with an open carrier (non-LSD). Might be better off to buy a diff already set up for a Nova so it is a bolt-in project.
The cam you choose depends on the rpm range you what the engine to operate in. Then, the rest of the setup will need to match the cam (compression, exhaust, intake, gears, stall, valve springs, ect). Kind of hard to tell if your cam choice is a good one without knowing what you want from your project.
Old 10-16-2006, 03:48 PM
bigbadbowtie's Avatar
Bottle Fed
If they are 041/041x,186,187,492 casting heads they can or will have acc holes. :-)
Chevrolet 327 TEEMCDEE9552 Engine 15 06-09-2007 08:22 PM
max valve lift for 1967 Chevy 327 camaro double hump heads?? kuhn-77 Engine 1 08-18-2006 06:12 PM
327 double hump heads on a 350 small block rhibbsiii Engine 3 02-19-2006 08:59 PM
327 block 350 crank neverstopped Engine 3 10-03-2003 08:55 AM
1968-69 327 1.72/1.5 Heads on 71 350 brennecke Engine 5 04-10-2002 08:56 PM
