Thread Tools Search this Thread share on Facebook
  #1
Old 12-15-2011, 06:32 AM
Tony Glass Tony Glass is offline
Old Faithful
350 & 350 in a '57 Chevy
I am installing a 350 and 350 in my '57 Chevy. To do so I am adding mid motor mounts and my question is: If I install the mounts between the block and the trans, will I have to shim the flex plate and do I need to do anything about the starter reaching the shimmed flex plate properly?
Register now (free) or login to remove ads
Old 12-15-2011, 08:01 AM
RWENUTS RWENUTS is offline
You don't need a complete mid plate and the problems associated with the install. Use a side mount like in the link. No starter or linkage probs either.
JMHO.
http://www.danchuk.com/ItemForm.aspx?item=870
Old 12-15-2011, 08:35 AM
Old Faithful
350 & 350
Thanks for the reference. I was looking at supporting the engine in case I had to pull the trans. at a later date. This will work for me. Thanks again.
Old 12-15-2011, 10:49 AM
ogre's Avatar
ogre ogre is offline
the 'Duracell Project'
it's been a while since i had my 57 moredoor, but as i remember they were similar to 55-59 trucks and have front and bell housing mounts. to mount a 350/350 you will need to add regular mid block motor mounts and a trans x-member mount, like all sbc since 1960.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "350 & 350 in a '57 Chevy"
ThreadThread StarterForumRepliesLast Post
153 tooth Chevy flywheel in an original '55 Chevy 3 speed stick.Classic Chevy DaveEngine209-17-2010 03:44 PM
newer chevy distributer in older chevy car,what are these four plugs?gearjammer38Electrical1108-09-2010 10:15 AM
Putting a 72' chevy 350 into 1995 chevy silverado that has a 4l80e transWillbee26Transmission - Rearend303-28-2010 10:40 PM
Can you use a 1933 or 1935 Chevy transmission in a 1934 Chevy?mistermusclesTransmission - Rearend007-18-2004 05:40 PM
1986 305 chevy vs. 1987 305 chevy new style small blockmtinsleyEngine208-22-2003 11:55 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
