Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350///357 build
Thread: 350///357 build
Old 11-12-2012, 04:00 PM
0trbo4myCHEVUICK 0trbo4myCHEVUICK is offline
[quote=ap72;1610343]
Originally Posted by 0trbo4myCHEVUICK View Post
they should be the correct height if they haven't changed anything.
As for weight matching you can do it yourself with a gram scale, or have a shop do it. you'll need to compare the specs before you buy though between your current piston and your next one- word of caution speedpro hyper pistons tend to be HEAVY. A set of very gently used stokc LT1 pistons may be better (they're hypers made by Mahle and lighter- but they have a metric ring pack).
So the LT1 pistons are a direct swap as any other piston? Is there a particular year of camaro? 1992 camaro pistons?
