Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350///357 build
Thread: 350///357 build
Old 11-13-2012, 05:09 PM
0trbo4myCHEVUICK 0trbo4myCHEVUICK is offline
Originally Posted by hcompton View Post
Dont fix the block fix the part you do not have already. First off with 64 cc you will have more than 8:1 you should be able to buy heads in 58cc.
When i run my 350 numbers with 64 cc heads i get much diferent numbers.
United Engine & Machine Co. Incorporated
Check this site. Off the top of my head the stroke for 350 is 3.48 with gasket of 4.063 min and .043 thick with .025 deck and +5 cc dish i get 9.7:1 unless your dish is even more than 5 cc. You will need to actually measure i think once you run all the numbers you can rasie the compression with thin copper gaskets if need be but try to aovid it. Also gas is **** these days better to stay safe. 10:1 on iron heads is pushing it.
???? I am under the impression that the pistons in my short block are around -33cc maybe more becuse they sit lower in the hole "rebuilder piston"
