Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350///357 build
Thread: 350///357 build
  #55 (permalink)
Old 11-27-2012, 07:20 AM
0trbo4myCHEVUICK 0trbo4myCHEVUICK is offline
Okay myabe this cam will be better suited for my combo.
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:1,300-5,500
Intake Duration at 050 inch Lift:217
Exhaust Duration at 050 inch Lift:225
Duration at 050 inch Lift:217 int./225 exh.
Advertised Intake Duration:270
Advertised Exhaust Duration:278
Advertised Duration:270 int./278 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.495 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.500 in.
Valve Lift with Factory Rocker Arm Ratio:0.495 int./0.500 exh.
Lobe Separation (degrees):110
Camshaft Gear Attachment:3-bolt
Computer-Controlled Compatible:No
Valve Springs Required:Yes
Camshaft Manufacturers Description:Good idle, street performance, strong lower to midrange. Stock converter OK.
