Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350///357 build
Thread: 350///357 build
  #120 (permalink)
Old 12-20-2012, 06:17 PM
techinspector1's Avatar
techinspector1 techinspector1 is online now
Senior Curmudgeon
Wiki Edits: 326
Originally Posted by 0trbo4myCHEVUICK View Post
Okay, measured with the feeler gauges. Placed the steel ruler in the 3-9 position if looking at the side of the block and measured from the squish band. Got .038..
was only able to measure the #1 piston at the moment.
And you jiggled the crank a little clockwise and counter-clockwise to make certain that the piston is at TDC, right? And no air gap under the rule at the block deck, right?
OK, now it'll be interesting to see what the other 3 corners look like.
This is one of the cornerstones of having a good build and not having a good build. The more information you can put together about various pieces in the motor, the better your choices will be for parts that contribute to the combination.
