Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350///357 build
Thread: 350///357 build
  #144 (permalink)
Old 12-27-2012, 05:26 PM
cdminter59 cdminter59 is offline
350///357 build
Man, I am tired of this wishy, washy back and forth. Do what you said you wanted to do. You didn't want to spend but $3000 right. Take the block to the machinist and let him check it out. You were going to get a Scat rotating assembly. It is a cast steel crank good to about 700 HP. Ask when purchasing the kit if they are using SCAT 2-ICR6000 PRO STOCK I BEAM CONNECTING RODS. They are 4340 forged steel. There are 4 different I-beam rods. The Pro Stock is the only 1 that is stroker clearanced. If you want them stronger upgrade to L19 or Arp 2000 rod bolts. Get the kit from CNC Motorsports their price is better and shipping is cheaper than Summit Racing. Call them on the phone to make sure you get the correct parts that you want.
