350///357 build - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 11-21-2012, 04:49 PM
I hope these serve me well for years to come
ID:	69277   Click image for larger version
  #47 (permalink)
Old 11-21-2012, 06:25 PM
350///357 build
Check out this cam, it will go good with the vortec heads. COMP Cams Xtreme Energy Retrofit Camshafts 12-412-8 - SummitRacing.com
  #48 (permalink)
Old 11-22-2012, 09:26 AM
Yes something in that area, I do have a OE roller block though. Im sorting through some now.. Really dont want to spend 300 on it.
Does the milling of the heads effect what pushrod length I require?
I plan on shifting this thing around 5200 on weekends. Is that a problem? friends say no, just wondering if I should install arp rod bolts while the oil pan is off.
  #49 (permalink)
Old 11-22-2012, 10:40 AM
Disregard shift point question im going to assume it's okay lol.. I have never owned a 350 so wasent sure about rpm range, at 3200 my 3.8l v6 sounded like a rc car motor.
  #50 (permalink)
Old 11-23-2012, 03:25 PM
Okay I am leaning towards this howards cam..
181145-10
Basic Operating RPM Range:1,500-5,600
Intake Duration at 050 inch Lift:219
Exhaust Duration at 050 inch Lift:225
Duration at 050 inch Lift:219 int./225 exh.
Advertised Intake Duration:272
Advertised Exhaust Duration:278
Advertised Duration:272 int./278 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.510 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.525 in.
Valve Lift with Factory Rocker Arm Ratio:0.510 int./0.525 exh.
Lobe Separation (degrees):110
Im looking for some imput hopefully I know cam selection has been beatin to death.
80's STOCK rebuilt short block. 4valve relief dish cast pistons.
906 vortec heads milled to 59cc ready for .600 lift. ( I know i need to change the .600 springs)
Im not sure what intake but probably a edelbrock 650 carb. havent bought intake stuff yet. No computer stuff for sure. vacuum brakes.
Its going in my 1982 chevy c10 long bed daily beatin truck.
I mud in it, I tow with it, I sit in traffic in it, I putt around downtown fort worth in it, I cruise long distance in it, and yes, I drag race in it. not very effectively but none the less I am always trying to beat up on rice zingers
It should be mentioned I have a RMVB TH400 I will be using.
stock gears 33x12 50 R15 rear tires.
I do not want to choose a cam based on my stock gears. I will be changing them. You guys rock
  #51 (permalink)
Old 11-23-2012, 09:53 PM
350///357 build
The cam is a good selection, I like Howards Cams. It is too late to replace rod bolts now. Usually you replace rod bolts then have rods checked and resized when everything is at the machine shop.
The Following User Says Thank You to cdminter59 For This Useful Post:
0trbo4myCHEVUICK (11-23-2012)
  #52 (permalink)
Old 11-23-2012, 10:55 PM
Okay got it. Nice to hear you like the cam thats unexpected!
  #53 (permalink)
Old 11-24-2012, 08:10 AM
Limited info on the net about this cam so far... Hoping to get a couple more opinions before I go out and shell the 300 for this dang thing. 200$ hotcam sounds alot nicer haha. No i like the howards better.
  #54 (permalink)
Old 11-24-2012, 11:30 PM
Anyone think different specs will do better for my combo?
  #55 (permalink)
Old 11-27-2012, 07:20 AM
Okay myabe this cam will be better suited for my combo.
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:1,300-5,500
Intake Duration at 050 inch Lift:217
Duration at 050 inch Lift:217 int./225 exh.
Advertised Intake Duration:270
Advertised Duration:270 int./278 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.495 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.500 in.
Valve Lift with Factory Rocker Arm Ratio:0.495 int./0.500 exh.
Camshaft Gear Attachment:3-bolt
Computer-Controlled Compatible:No
Valve Springs Required:Yes
Camshaft Manufacturers Description:Good idle, street performance, strong lower to midrange. Stock converter OK.
  #56 (permalink)
Old 11-30-2012, 09:11 AM
Now that cam selection is out of the way, Ive been looking at steel skip white full roller rockers. does anyone have experience with them? The price seems pretty low.. Im sure the "lifetime warranty" only covers if they break in half or something but still seems like a good deal.
My vortec heads have guide plates and screw in studs. I need to be looking at narrow body rockers right?
Im still looking for a couple more opinions
I was under the impression that I would need to change my valve springs
135 lbs. @ 1.750, 325 lbs @ 1.200 (1.250 diameter) sais good for .600 lift cam.
I can use my .500 lift cam with these springs? I assume they are for a roller cam as they are on vortecs?
  #57 (permalink)
Old 11-30-2012, 10:09 AM
Last journal entry: Paint
I would use what you already have. Why would you buy a different set of pistons for a little bit more compresson? Then you are going to have to get new pistons pressed onto the rods. You might not even notice the difference in the performance. You can buy a used roller cam on Ebay, they are reuseable. If you don't want what you already have sell it. It might not be easy to sell and then you will have to find something else.
  #58 (permalink)
Old 11-30-2012, 10:12 AM
How much is all that going to cost? You will turn a $400 dollar short block into something that cost thousands.
  #59 (permalink)
Old 11-30-2012, 10:28 AM
Yes I am leaving the short block as it is. Except for the stock flat tappet cam.
Im sure there was A cheaper way of doing this but it is what it is. Im looking at 1600 for the long block. I need to buy Roller rockers next and am looking for anyone that has exp with skip whites steel rockers. Or is there some nice GM rockers I can use? My vortecs have guide plates installed.
  #60 (permalink)
Old 11-30-2012, 10:33 AM
You could probably buy a used late model LS engine and buy the aftermarket intake for a 4 bbl carb on what you are trying to do to a $400 shortblock. That shortblock was not a bad deal as long as you don't end up spending a lot of money to make it work.
trying to build a 357 Newbie3191 Engine 8 07-01-2010 10:10 AM
HP and TQ Guesses of my 357 build ORANGEGASM Engine 2 08-13-2008 07:08 PM
357...??? jkingof9561 Engine 2 05-04-2008 03:18 PM
357 ci chevy bstout3 Engine 1 11-20-2004 06:00 PM
breaking in my 357... Sagacious Engine 3 08-05-2004 04:51 PM
