350///357 build - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 11-30-2012, 10:51 AM
Originally Posted by V8&4spd View Post
You could probably buy a used late model LS engine and buy the aftermarket intake for a 4 bbl carb on what you are trying to do to a $400 shortblock. That shortblock was not a bad deal as long as you don't end up spending a lot of money to make it work.
I am not changing the shortblock just doing a cam swap. and yeah I could have went and got a 300$ used vortec and slapped a carb on if I wanted a used engine.
  #62 (permalink)
Old 11-30-2012, 10:56 AM
Looking for help on the valve springs, Im not sure how close is "close enough" as far as specs go.
The recommended valve springs for the xr270hr ( I am getting the howards version) are
132 @ 1.750 293 @ 1.250
the springs on my vortecs are
135 lbs. @ 1.750, 325 lbs @ 1.200
Pretty close at 1.750, pretty large difference on the second spec..
  #63 (permalink)
Old 11-30-2012, 12:15 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Don't go for the pitfall of close enough.To much pressure is going to wear the lifter/cam prematurely.The Howards is a quality cam and you should go back to Competition Products to get the matching springs.Just do it right.
  #64 (permalink)
Old 11-30-2012, 01:09 PM
lame.
Maybe I can sell these other spring they are new
  #65 (permalink)
Old 11-30-2012, 02:30 PM
Originally Posted by 0trbo4myCHEVUICK View Post
lame.
So if there are shims, i might beable to lower my spring pressure?
  #66 (permalink)
Old 11-30-2012, 04:35 PM
Okay well actually comp suggests 2 different springs for this size cam. My springs are alot closer to the 2nd option.
option 1. 986-16 132 / 293
option 2. 987-16 121 / 343
current springs 135 / 325 -
almost the seat of the first and open of the 2nd...?
I think I will be okay... accounting for loss of pressure I would be even closer to the recommended spring after a year lol.
  #67 (permalink)
Old 12-02-2012, 10:59 AM
I've been looking into isky roller cams in the same profile range as the XR270HR.
Im wondering if a cam has an operating range of 2000-6000 on a 112lsa, how much will the rpm range change going to a 110 or 108?
The lift/duration specs are VERY similar to the 270 but the 270 is on a 110 and starts 500rpm sooner.
I dont want a comp product and have heard very good things about isky from alot of my dads old school friends.
  #68 (permalink)
Old 12-04-2012, 08:34 AM
Somewheres along the line I read that you should not use full roller rockers on an engine with less than 350# of spring pressure. Mine has 325# and am ready to buy the skip white steel rollers ive been looking at, should I be looking into roller tip rockers? seems like the full roller would be better in any case...?
  #69 (permalink)
Old 12-06-2012, 02:31 PM
Well I've decided on 60121voodoo cam with ls7 lifters.
My wifes birthday is dec.28th and my sons birthday is new years day so with christmas on top of that, the engine fund has been depleted! Going to order some scorpion rockers in a couple days but no more parts untill mid jan.
Ill post more pictures and stuff when I get the rockers in
  #70 (permalink)
Old 12-06-2012, 04:03 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
[quote=0trbo4myCHEVUICK;1610332]
Originally Posted by techinspector1 View Post
I don't understand why you would buy a completed short block and then want to begin changing parts, but hey, whatever.
As this is my first build... I'm sure this wont be the first inefficient move I make.
I screwed up and jumped the gun on this deal. Now im hoping I will beable to install the new pistons myself? I assume I need to take the old piston/rod combo and have a shop switch the pistons?
Also I believe the H345CP speed pro hyper piston is a standard compression height piston.
False they are 1.548". I bought them assuming they were, Summit misadvertised them as 1.560".
  #71 (permalink)
Old 12-08-2012, 09:40 AM
[quote=Silver Surfer;1619902]
glad I didnt buy them then jeez. In A couple years when I go 383, Ill get some standard height pistons. Untill then these are gonna have to do. 423NP
  #72 (permalink)
Old 12-15-2012, 05:18 PM
Can you fellas help me figure out which timing set I need? voodoo 60121 cam in 1988 tbi block with vortec heads...
  #73 (permalink)
Old 12-15-2012, 10:35 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
got a link to cam?
  #74 (permalink)
Old 12-16-2012, 12:09 AM
Voodoo Hyd Roller Cam - LT1 LT4 270/278 - Lunati Power
  #75 (permalink)
Old 12-16-2012, 09:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Why an LT cam? Does this cam have a fuel pump eccentric- if you even need one, I don't know what you plan on doing w/this deal.
You have to shorten the cam dowel/drive pin to use the LT cam. No big deal (in some cases the pin can be driven deeper into the front journal), but there are thousands of hydro roller cams made for that engine that'll fit w/o any extra work. You cannot find anything but an LT cam?
trying to build a 357 Newbie3191 Engine 8 07-01-2010 10:10 AM
HP and TQ Guesses of my 357 build ORANGEGASM Engine 2 08-13-2008 07:08 PM
357...??? jkingof9561 Engine 2 05-04-2008 03:18 PM
357 ci chevy bstout3 Engine 1 11-20-2004 06:00 PM
breaking in my 357... Sagacious Engine 3 08-05-2004 04:51 PM
