All the pictures im seeing of the lt1/lt4 voodoo cams have the fuel pump lobe. Guess ill see for sure when it gets here in a few days. Bought the ls7 lifter kit too..
I was looking at the Scorpion platinum steel rockers? Just trying to make sure the only mod i would need to do is the work on the valve covers? Im thinking I want to stay away from the narrow body rockers... |
I skimmed through 6 pages of this thread and still haven't seen anything about the wt of the vehicle,type of trans,rear end gear ratio,size of tire,yet a cam choice was make..................
Its a 1982 Chevy C10 single cab- Not sure how much it weighs in at.. Should be 36-3800 I would think? 33" tall tires, Its got the stock gears in it right now but Im looking into 3:73 or maybe even steeper with the tall tire... not sure just yet.. Ive got A RMVB TH400 for it. Going to buy 24-2600 stall after christmas. Dual trans coolers with fans and deep pan with cooling fins. |
Im wondering about these scorpion steel platinum series rockers on the vortecs(guideplates)..... Wondering how they compare with the heavier endurance or race series.
If I use taller centerbolt valve covers I might not need to grind out baffles? Its not a big deal if I need to, just a quick zap with the angle grinder. Def dont want to do any grinding on the rockers though. especially if theres already been material removed for weight reduction. i would assume that the rockers are weaker and will not last as long in exchange for the benefits of less weight? I would rather get the heavier series if that is the case.. Im just pretty sure I want to stay away from narrow bodies. |
Scorpion is a good brand and I have actually used them in the past. I didn't know they had come out w/steel Platinum series rockers. The aluminum rockers are good to an ungodly amount of spring pressure (I don't recall how much but it was a LOT) so I wouldn't worry a bit about their strength, even w/a narrow body. As long as they clear the center bolt valve covers you're good to go, IMO. Just be sure to match the stud size of the head to the rocker when you order them. |
Hey guys. I don't mean to barge in but I have a ralated question. I'm rebuilding a 355 and I have balanced the pistons/ rods within 1/2 a gram. Do I still use the same harmonic balancer?? (external balancer) I have not had the crank balanced, or do I need to change to a neutral or fluid balancer. Again I'm assuming a 400 balancer is neutral. Thanks for anybody help!!!!!
First off I have nothing but respect for all of the guys that invest their time and knowledge helping young gear heads figure it out and I ALWAYS remember that I dont have all the answers. I try to take full advantage of the resources available on this forum. THANKS! Now, I am confused. Does scorpion even make a steel rocker? JEGS has a selection of scorpion rockers listed under "STEEL ROCKERS", "race" "endurance" "platinum" Summit has NOT ONE scorpion rocker listed under steel, only alum. |
Regardless, One of these three will be the rocker I get.
Just trying to figure out which would be the best for my daily driver. endurance race or platinum. Do you only see the benefits of a lightweight rocker arm at HIGH rpms? I dont plan on revving past 5500 but I DO want to go overkill on some parts. Well sure havent seen very much on the net about the platinum series, Unless I catch some wind otherwise, These will be the ones I get. Im going to give Scorpion a call in the morning and check the spring pressure ratings on the endurance compared to the plats. I just assume the platinums would be weaker with their lighter weight. My springs are 135 lbs. @ 1.750, 325 lbs @ 1.200 1.250 diameter Last edited by 0trbo4myCHEVUICK; 12-17-2012 at 06:42 PM. |
I'm going by what you said:
Anyway, the Platinum series aluminum rockers will be great. You need not worry about strength but sure, talk to them to verify the fit w/the Vortec/center bolt valve covers.
You mentioned timing sets earlier. I have used the Cloyes p/n 9-3157 set- it's a true roller but not a double roller. There's also the 9-1157 double roller but I have not used it so cannot say if the block needs to be clearanced or the timing cover spaced out to use it or what. I bet if you research it you'll find out, though. Pro Gear is another name that comes up a lot w/the LT1/4 crowd. You might want to see what they have for the Gen 1 SBC w/an OEM roller set up. I have no problem using a single roller timing chain/set. Double roller sounds like it's stronger, but if it were all that and a bag o' chips I'd expect to see it on a motorcycle! lol |
Yeah Cobalt.The single larger motorcycle style link timing chains are superior.
Well cool, just got off the phone with lunati. The man said the lt1/lt4 voodoo cams DO have the fuel pump lobe and the dowel pin is designed to be knocked back to proper length for a non lt1/lt4 OE roller block. So no grinding!
He also recommended timing set Full Roller Timing Set - Chevrolet 262-400 (w/roller cam) 3 keyway - Lunati Power Full Roller Timing Set - Chevrolet 262-400 (w/roller cam) 3 keyway Product Description Full roller timing set for Chevrolet 262-400 (w/ roller cam) applications •Keyway(s): Three (+-4, 0) •Roller Diameter: 0.250 in. Part Number: 93026 Previoius Part Number: 93026LUN Jobber Price: $70.27 He also stated the recommended valve springs for this cam are too weak. He couldn't say for sure about my springs without knowing the brand and type. I gave him the spring specs I have and he said that they SOUND perfect for the application, but could not know for sure without further information. Im going to run the springs I have. I was also getting conflicting information on if the lift numbers were advertised with a 1.5 or 1.6 rocker. Some sites just say "factory rocker arm ratio" and some sites say with a 1.6 rocker. He confirmed the lift numbers are with a 1.5 ratio rocker, which is a relief. Gonna call scorpion next and try to talk rockers with them. |
| trying to build a 357 | Newbie3191 | Engine | 8 | 07-01-2010 10:10 AM |
| HP and TQ Guesses of my 357 build | ORANGEGASM | Engine | 2 | 08-13-2008 07:08 PM |
| 357...??? | jkingof9561 | Engine | 2 | 05-04-2008 03:18 PM |
| 357 ci chevy | bstout3 | Engine | 1 | 11-20-2004 06:00 PM |
| breaking in my 357... | Sagacious | Engine | 3 | 08-05-2004 04:51 PM |
