350///357 build - Page 8 - Hot Rod Forum : Hotrodders Bulletin Board
  #106 (permalink)
Old 12-19-2012, 04:48 PM
Originally Posted by techinspector1 View Post
Dude, your next purchase should be a 6" dial caliper. Expect to pay about 80 bucks for a used Starrett, Brown & Sharpe or Mitutoyo on ebay. Here's an example:
Starrett 120A 6" Dial Caliper Hardened Stainless Steel Black Dial Face B120A 6 | eBay
Don't buy a digital, because every time you reach for it to use it, the battery (batteries) will be dead. Dial calipers are bulletproof.
yeah I know please excuse my red neckedness.... I thought I could just put a toothpick on the quench band n cut it where it meets the deck. Then id take me that there ruler n get an exact measurement.. lolo
  #107 (permalink)
Old 12-19-2012, 04:55 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Originally Posted by 0trbo4myCHEVUICK View Post
1/15" from the raised lip to deck surface.... I was not able to measure all four corners becasue of where the block is but once I get it on a stand I will.
Are you saying it took a .015 blade to span the gap? 1/15th is not a viable measurement.
  #108 (permalink)
Old 12-19-2012, 05:05 PM
I dont have proper tools and im using this thing you see in pics, theres the 1/8th mark, then in the middle of that would be the 1/16th mark. I am one notch above the 1/16th mark. Im trying to find the darn thing so i can take a picture but I seem to have misplaced it... probably for the better..
  #109 (permalink)
Old 12-19-2012, 05:11 PM
Senior Curmudgeon
Wiki Edits: 326
All you need is a steel rule and a $5.00 set of feeler gauges to get the dimension right on the money.
  #110 (permalink)
Old 12-19-2012, 05:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Maybe a typo for 1/16" (0.0625")?
Anyway, the measurement need to be made at least w/feeler gauges between the quench band and the straight edge across the deck, spanning the bore. If you use a ruler, tip it up on its short edge, not laying flat where it can bow.
Below the piston is a true flat top. You would do the same thing except measure to the quench band of your piston:
The Following 2 Users Say Thank You to cobalt327 For This Useful Post:
0trbo4myCHEVUICK (12-19-2012), techinspector1 (12-25-2012)
  #111 (permalink)
So if you can see where the 1/16th mark would be I am one notch above that mark.
ID:	69920   Click image for larger version
ID:	69921   Click image for larger version
  #112 (permalink)
Old 12-19-2012, 05:23 PM
Okay, I will stop by the store tomorrow and buy the feeler gauges and straight edge.
  #113 (permalink)
Old 12-19-2012, 05:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The finest scale resolution is 1/64". So are you saying 5/64"? That would be 1/16" (4/64) plus 1/64 = 5/64". I hope it's not that, it would be a quench measurement of a whopping 0.078". Not good.
In any event, using a ruler like that is not accurate enough IMHO.
Edit I see you're getting feelers tomorrow. Good deal.
  #114 (permalink)
Old 12-19-2012, 05:32 PM
:/ By the looks of the thing and other pictures I have seen on the net. It doesent look like my pistons are very far down in the hole at all. now im nervous as heck.
  #115 (permalink)
Old 12-19-2012, 05:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That would be a good thing- if they were even with the block it would be even better. I'm going to guess they're 0.045" down the hole.
  #116 (permalink)
Old 12-19-2012, 09:49 PM
Nah if they are even with the deck my compression will be too high i think.
  #117 (permalink)
Old 12-19-2012, 11:19 PM
1Gary's Avatar
Last journal entry: Ole Yellar build-1989 383 SBC Astro build
Technically the chamber volume includes the space between the deck the top of the top ring.In cases where you where right at the rag-get edge of a limit then that would be important. Some piston companies move the top ring down because of the application and heat issues.
  #118 (permalink)
Old 12-20-2012, 08:26 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That would depend on the chamber volume of the head and the dish volume of the piston, now wouldn't it. You did read the page on quench, right?
The "ideal" quench measurement is right at 0.040". About the most common composite head gasket thickness is 0.041". So a zero deck (piston even w/the block) and a 0.041" head gasket will put the quench measurement right where it needs to be.
You do not want to adjust the compression ratio by making the quench distance wider. So using a thicker head gasket or a piston deeper in the hole are both bad plans as compared to a zero deck and a 0.040" range head gasket- or any other combination of HG thickness/piston deck height (piston in the hole) that equals about 0.040".
The Following User Says Thank You to cobalt327 For This Useful Post:
0trbo4myCHEVUICK (12-20-2012)
  #119 (permalink)
Old 12-20-2012, 03:54 PM
Okay, measured with the feeler gauges. Placed the steel ruler in the 3-9 position if looking at the side of the block and measured from the squish band. Got .038..
was only able to measure the #1 piston at the moment.
  #120 (permalink)
Old 12-20-2012, 06:17 PM
Senior Curmudgeon
Wiki Edits: 326
And you jiggled the crank a little clockwise and counter-clockwise to make certain that the piston is at TDC, right? And no air gap under the rule at the block deck, right?
OK, now it'll be interesting to see what the other 3 corners look like.
This is one of the cornerstones of having a good build and not having a good build. The more information you can put together about various pieces in the motor, the better your choices will be for parts that contribute to the combination.
trying to build a 357 Newbie3191 Engine 8 07-01-2010 10:10 AM
HP and TQ Guesses of my 357 build ORANGEGASM Engine 2 08-13-2008 07:08 PM
357...??? jkingof9561 Engine 2 05-04-2008 03:18 PM
357 ci chevy bstout3 Engine 1 11-20-2004 06:00 PM
breaking in my 357... Sagacious Engine 3 08-05-2004 04:51 PM
