I don't understand why you would buy a completed short block and then want to begin changing parts, but hey, whatever.
Pay attention to the compression height of the pistons you plan to buy. Stock CH for a 350 Chevy is 1.560", but rebuilder pistons have a shorter CH (1.540") to compensate for shortening the deck height of the block. The shorter CH will make it more difficult to achieve a tight squish. Hang just the tip of one jaw of a dial caliper into the top of the pin bore and the other jaw at the crown just above the top ring. A 1.560" CH piston will measure 1.096"/1.097". Last edited by techinspector1; 11-12-2012 at 10:03 AM. |
When you buy your pistons I'd buy a set that is close as you can get to the same weight as the ones you have, then balance them to match the pistons already in the block. It'll save you from having to rebalance it.
[QUOTE=techinspector1;1610307]I don't understand why you would buy a completed short block and then want to begin changing parts, but hey, whatever.
As this is my first build... I'm sure this wont be the first inefficient move I make. I screwed up and jumped the gun on this deal. Now im hoping I will beable to install the new pistons myself? I assume I need to take the old piston/rod combo and have a shop switch the pistons? Also I believe the H345CP speed pro hyper piston is a standard compression height piston. Last edited by 0trbo4myCHEVUICK; 11-12-2012 at 11:13 AM. |
[quote=0trbo4myCHEVUICK;1610332]
As for weight matching you can do it yourself with a gram scale, or have a shop do it. you'll need to compare the specs before you buy though between your current piston and your next one- word of caution speedpro hyper pistons tend to be HEAVY. A set of very gently used stokc LT1 pistons may be better (they're hypers made by Mahle and lighter- but they have a metric ring pack). |
[quote=ap72;1610343]
[quote=0trbo4myCHEVUICK;1610404]any LT1 piston will work, you will need to get the correct rings though, and will have to check balance on everything again. You can try buying them from a yard but you can also watch local ads, craigslist, ebay, etc.
From the pictues it looks like your block has new pistons in it. What is the purpose for the change? With 64 cc heads looks to me like your going to be close to 9.5 to 1 and use larger gasket if need be. Correct me if im wrong but arent the 4 valve flat pistons +5 cc right?
I would save the piston money and get aluminum heads. They will hold up and make good power. More importantly they are in the block and ready to go. Unless you want to run n2o i would leave them in place. You can use a press to remove and install piston pins. They are cheap at harbor freight and always good to have around the shop. If not im sure at least one of your freinds has a press. If not machine shop should be very reasonable on this work. |
[QUOTE=hcompton;1610421]From the pictues it looks like your block has new pistons in it. What is the purpose for the change? With 64 cc heads looks to me like your going to be close to 9.5 to 1 and use larger gasket if need be. Correct me if im wrong but arent the 4 valve flat pistons +5 cc right?
I wish those were 4valve relief flat tops but they are stock style dish... |
[quote=0trbo4myCHEVUICK;1610538]
What's the purpose? What's the budget? What's the platform? Maybe I missed it somewhere? |
The pistons have 423Np stamped on them. Probably a rebuilder piston. Like i said i jumped the gun on this deal and bought the thing before i did research on the pistons.
Looks like I would be lucky to have 8:1 compression with these pistons and probably wouldnt even have that. I dont want to build a dog of an engine i want good quench and strong compression. I have been looking at H345CP speed pro hyper pistons, they state 9:25 compression with a 64cc head. Now I am wondering about my rods, I know they have been "resized". Does that mean I should NOT be looking for a piston designed for a 5.7 rod? I cant seem to find a weight spec on either one of these pistons and I know about balancing issues.... |
Dont fix the block fix the part you do not have already. First off with 64 cc you will have more than 8:1 you should be able to buy heads in 58cc.
When i run my 350 numbers with 64 cc heads i get much diferent numbers. United Engine & Machine Co. Incorporated Check this site. Off the top of my head the stroke for 350 is 3.48 with gasket of 4.063 min and .043 thick with .025 deck and +5 cc dish i get 9.7:1 unless your dish is even more than 5 cc. You will need to actually measure i think once you run all the numbers you can rasie the compression with thin copper gaskets if need be but try to aovid it. Also gas is **** these days better to stay safe. 10:1 on iron heads is pushing it. |
Oh and still dont replace the pistons deck the block its cheaper than new pistons if you can take it apart your self and bring it to the machine shop bare. Hope this helps.
???? I am under the impression that the pistons in my short block are around -33cc maybe more becuse they sit lower in the hole "rebuilder piston" |
| trying to build a 357 | Newbie3191 | Engine | 8 | 07-01-2010 10:10 AM |
| HP and TQ Guesses of my 357 build | ORANGEGASM | Engine | 2 | 08-13-2008 07:08 PM |
| 357...??? | jkingof9561 | Engine | 2 | 05-04-2008 03:18 PM |
| 357 ci chevy | bstout3 | Engine | 1 | 11-20-2004 06:00 PM |
| breaking in my 357... | Sagacious | Engine | 3 | 08-05-2004 04:51 PM |
