350 to 383 need little hlp - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2013, 08:23 PM
Hi all i got a 350 4bolt main and a broke my crank so i wanna 383 with it i have look on ebay for the part i need and i wanna make sure its all it take so they give me
1 crank 8piston and conecting rod this is all i need to make that 383 stroker ? Thx
(Sorry if its hard to read im french )
Old 08-18-2013, 08:31 PM
BOBCRMAN@aol.com's Avatar
You will also need a balancer and fliwheel/flexplate compatable with the mentioned parts.
Old 08-18-2013, 09:39 PM
My engine is old one cast 3970100 69-74 andmy old dlywheel wont fit anymore ?
Old 08-19-2013, 03:31 AM
Most 383 strokers use a 400 balancer and flywheel. To match tne crank.
Old 08-19-2013, 04:19 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
What Bob is saying to match the crank for balancing.
Old 08-19-2013, 04:48 AM
jokerZ71's Avatar
Wrench Turner
Beware of some of those kits on EBay.Some of them are not up to par.Most of the better kits will include the flexplate & balancer.Post a link to the kit on here & let some the guys here look it over before you buy.You will also need some machining done on your block for clearance.Your block should be a 2 pc rear seal.Make sure of this & then buy the correct kit.There are also other things you will need in order to make your 383 perform well with the extra cubes you will be adding.
Old 08-19-2013, 06:13 AM
vinniekq2's Avatar
Bienvenue.
Do you have a total picture plan for your engine?
Where are you located?Do you have access to a professional machine shop?
Old 08-19-2013, 10:57 AM
Conversing with another fellow I sent him this link on the subject from CarCraft magizine of about 4 -5 years ago. It is pretty detailed on what it takes to turn a 350 into a 383.
383 Stroker Small Block Chevy - Car Craft Magazine
Bogie
Old 08-19-2013, 11:10 AM
The mobile view is crap
You need to get your block to a machine shop and prepped before buying any parts. Don't want to buy .030 over pistons and then find out they had to bore larger to get the blocked right. You also wanna make sure it's a factory sized block that hasn't already been already bored over. After your machinist is done he will try to sell you parts.
whats better 400 crank or a 383 crank in a 350 sbc when trying to build a 383? onlychevy Hotrodding Basics 14 12-28-2012 07:27 AM
need hlp cant found what engine i got :( camaro1982 Hotrodding Basics 6 07-31-2012 10:09 AM
350 to 383, works with my 350 rods and pistons? Berres Engine 2 07-27-2009 07:51 AM
Car Skipped than Died? WHY? HLP calimstng66 Engine 3 11-22-2004 05:30 AM
383?? or 350?? Trav Engine 4 08-09-2003 02:19 AM
